LS1 crank in an LS3 block?
LS1Tech Premium Sponsor
Yes sir, that will work! Make sure you balance the assembly, as always. Also, you'll need to run the LS2 timing set with the 1X cam reluctor so your PCM will run it properly.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Yes sir, we stock the Rollmaster, N-Motion, and Comp Cams timing set you need!
__________________
