Who has a Texas Speed Heads and Cam Package and are you happy with it?
Old 12-11-2011, 05:56 PM
SWEET98SS's Avatar
Default Who has a Texas Speed Heads and Cam Package and are you happy with it?
I am debating on what heads/cam package to go with and am considering the texas speed head and cam package for my ls1.
Please post
- what setup do you have
- dyno numbers
- track numbers
Old 12-11-2011, 07:39 PM
k_garretson23's Avatar
They offer a lot of heads/cam packages which one in particular are you considering, what are you looking to achieve as in power numbers/gains?
Old 12-11-2011, 07:49 PM
SWEET98SS's Avatar
I have only really looked quickly but I am looking for something that has been thought out and paired together. I looked at the V3 and heads package.
I had the streetsweper cam, 236/240 .615/.615 111 LSA, actually still have it but had some oil pressure problems. Cam is shot as well as lifter.
I really like the power of the streetsweeper but I would like more power under the curve instead of always having to rev the car to 6800 rpms. Also, the car drove crappy at low rpms.
I put about 10,000 miles on the car a year, track once or twice a year. I want something with great street manner and that makes more power than my cam only. So if it made 440 rwhp, I would be happy.
Old 12-11-2011, 08:00 PM
studderin's Avatar
Sucks to hear about the cam damage. You dont have to rev that cam to 6800, why are you? I would go slower shifting it there, I think it peaks at about 6300. My car was the fastest with my shiftlight set at 6400rpm BTW. went 10.6s 128's. Id like to know what you go with, and what you think about it. Sounds like you want a smaller cam, but I would keep it and just get a better rear end with some gears. Its not even recommended to run any cam that big with stock gears. A few guys have made 500whp with it and good heads. A goal of 440 you can do with stock 243s, if your going to get a good ported head. A little 224R will do it to, and you would like it better with the stock gears.
Old 12-11-2011, 08:07 PM
SWEET98SS's Avatar
Now that you mention it, I think my shift lite is set lower at 6600 or maybe lower, I remember you mentioning it went slower at the higher rpm.
Check the internal section for my other post, cam and lifters are shot so I need a new cam now. The heads are the 853's and the machine shot said like $500 to redo them with stock springs so probably $600 with better springs. Im going to get the bottom end redone and put the rest of it together myself, they want $700 to assemble it.
Old 12-12-2011, 06:56 PM
SWEET98SS's Avatar
Up to the top, thougth there would be more responses to this.
Old 12-13-2011, 09:58 AM
Cajun99SS's Avatar
Im satisfied with mine but i think im gonna go with a custom cam and try to get a little more out of it. Cant remember the unlocked dyno numbers but locked it did 400. something but my stock trans was acting up. Since that dyno i put a performabuilt lvl2 and switched from a fuddle 3600 to ss4000 and from 3.23s to 3.73s. Best track time is in sig
Old 12-13-2011, 11:56 AM
sscamaroburn02's Avatar
I have the Tsp 2.5 heads out of the box and the 233/239 cam. With Fast intake and full exhaust car made 431 pretty good numbers for a budget package and M6. It will surge slightly down low but that is because of my stock gears. I can't complain I love the way my car drives and wouldn't have done anything different.
No track times yet just FYI
Old 12-13-2011, 12:05 PM
need2speed94's Avatar
If you want a better DD cam, 224R or 228R is very popular for more mild cams. I saw the specs of the streetsweeper and it's a cam that most would hate to DD, some don't mind. You could always get it tuned to drive to your standard if you end up keeping it.
Old 12-13-2011, 04:26 PM
Captain Double Post
BOBS99SS's Avatar
Anyone is going to hate that cam with stock gears that's a given. That is a Badass cam it just needs the 4.10 or higher gears, listen I would go with a custom cam matches to some prc227s, but honest man that streetsweaper with some decent heads and some gears will make you very happy.my ms4 car sucked so bad with stock m6 gears, put some 4.30s in there and its a different ball game
Old 12-13-2011, 04:48 PM
mayo06gt's Avatar
Im real happy with mine it made 487hp n/a and 637 hp with 150 shot on a stock bottom end
Old 12-13-2011, 05:00 PM
Fafonfoe's Avatar
I have a head cam package. I had a stock LS2 from a GTO and bought their LS6 Heads Stage 2.5 and 231/236/112 cam. With my headers,exhaust and H/C package I dyno @ 474 at the wheels. 430 torq. Heads looked great when they got here and was very pleased with the service and quality of their products. Best customers service I have ever had from any company.
Old 12-13-2011, 08:31 PM
SWEET98SS's Avatar
Thanks for all the replies. I dont daily drive my car, have a beater for that. I would actually keep the streetsweeper but I pulled the lifters and cam. Its shot.
Looks like it a valve hit the piston also. I dont want to have to flycut. I am going to have the bottom end redone with new bearings, rings and a hone. I will be putting it together myself.
Attached Thumbnails Who has a Texas Speed Heads and Cam Package and are you happy with it?-img_0354.jpg   Who has a Texas Speed Heads and Cam Package and are you happy with it?-img_0355.jpg   Who has a Texas Speed Heads and Cam Package and are you happy with it?-img_0356.jpg
Old 12-13-2011, 08:40 PM
hardcore's Avatar
Couldn't be happier with my PRC237 and 239/247 head and cam package
Matt's the man!!
Old 12-14-2011, 05:48 AM
Captain Double Post
BOBS99SS's Avatar
if your going to rebuild i would flycut, get the same cam, and get a damn rear, with some good heads you will be happy
Old 12-14-2011, 06:40 AM
smg267's Avatar
Have almost the same set up add a 85maf, cutout, ported fast with a baby 228/ 230 .571 .579 ? on my car. Made 430/400. Was hoping a little higher but seems to be about right with your numbers.
Old 12-14-2011, 06:58 AM
StrokedEVO's Avatar
very happy with my PRC stage 2.5 5.3l heads and a TSP torquer v2 on a .114 its in a 02 camaro a4 with a midwest 3500 stall and bolt ons... no dyno numbers but it moves out! on a stickey tire its a 11.4-11.7 at 117-120mph
Old 12-14-2011, 07:17 AM
yep I'm getting suspension right now and then on to a better rear end!
Old 12-14-2011, 10:13 PM
SWEET98SS's Avatar
Thanks for all the replies. I actually priced out staying with the streetsweeper cam, it is the cheapest route as I dont need to get new heads, tune,pushrods or springs. I am still not convinced to stay with it though. It would be nice to try something different since I do have the whole car apart.\
I do see everyone is happy with the texas speed products, one of the reasons I chose to take a look at them.
Old 12-15-2011, 08:17 PM
SWEET98SS's Avatar
I thought there would be alot more people posting in here. I guess if there arent as many TSP head and cam users.
Post up if you would recommend a head cam package.
Quick Reply: Who has a Texas Speed Heads and Cam Package and are you happy with it?
