Help.. With a Cam..
Help.. With a Cam..
I no where is a lot of LS1 cams out there... But which!! or Who make a cam that make good Power!!!! 02 Camaro (Stock Bottom End & Heads) But has all the other bolt on's 3800 Cov. 373 gear... Thanks Poor...
Typically a TSP cam will suit your needs. With a 3800 stall, you could get a decent size cam, such as the MS3. That's the easiest route.
x2 on the custom cam though. Msg Pat G on here and he can set you in the right direction. That would be your optimal choice to maximize power and suit your needs in terms of driveability, performance, and the like.
Good luck with your builds. Everyone starts somewhere, just some get solid advice and some get jackasses with jajajajas as a reply.
I'm new to the site!! You are right!! And was just looking for some Help.. So i just strated to read-the Vendors list like the guys in the other post said... I have been street/drag racing a long time.. But with BBC/SBC with carbs.. So like i said in one of the other post.. The ls1 motors are new to me..
well if you've been racing for awhile you should have a good feel for what kind of cam you want. They aren't drastically different from the SBC stuff. Just go to comp cams page or Thunder racing and you can go through all the Ls1 cams that are there. Its not exactly rocket science, just sayin...
If you're looking to maintain driveability, check out my thread: https://ls1tech.com/forums/generatio...veability.html
A lot of good suggestions in there. Just do some searches and read. I'm so tired of reading about cams...
