please help!!! Anyone
Old 12-20-2011, 03:44 PM
AppleFirebird's Avatar
Exclamation please help!!! Anyone
i replaced the motor on my headlight and having trouble when i turn the switch to the on position one headlight goes up and the other headlight down why??? anyone pls help me!!!!!!
Old 12-20-2011, 03:49 PM
Happytokr's Avatar
You have the wires crossed on the headlight motor. There are 2 wires that control the lift and down and if they are crossed will cause that problem.
Old 12-20-2011, 03:53 PM
jaysan's Avatar
Is it doing this ?
http://www.youtube.com/watch?v=ovnQtOTlRQ4
Old 12-20-2011, 03:56 PM
Happytokr's Avatar
Yes I know cause I have mine bypassed on my TA and when the wires are crossed then it causes the headlights to do that
Old 12-20-2011, 03:59 PM
ANTICOP RAM AIR's Avatar
lol..manually lower the one light, then it will be back in sync..
Or, an easier way, Turn the lights off.. have someone hold the open lamp up and then turn the lights on.. that will put them back in sync... been there done that..
Old 12-20-2011, 04:01 PM
call me man..
Old 12-20-2011, 05:37 PM
enigmah's Avatar
If its not wired backwards there is actually a box that controls the headlights, it might be bad. I had so many problems with mine it was unbelieveable. I changed the motors, I changed the gears to metal, I did everything. I even hardwired it, i finnaly took it to a stealership and they replaced a relay box by the headlights and it worked like a charm. Damn I was mad lol
Old 12-20-2011, 06:49 PM
yeah thats what it does how did u do it to fix it???? please help
Old 12-20-2011, 07:12 PM
enigmah's Avatar
You have to replace the box man... Im 90% sure its bad.
Old 12-20-2011, 07:22 PM
jaysan's Avatar
Check the long metal arm looking think that sits on that white rubber piece . Mine did that I had to adjust it and now it works fine . Use the correct working headlight as your model .
Old 12-20-2011, 07:28 PM
ok then
Old 12-21-2011, 04:41 PM
Angry
i still need help with the headlight problem
Old 12-21-2011, 06:18 PM
jaysan's Avatar
Remove the arm and lower the headlight manually . Put the metal arm back on and bolt the tornillo
Old 12-22-2011, 04:40 PM
philip052374's Avatar
i have the same freakin problem. Everything worked fine, except the passenger motor made a grinding noise on closing. Put in a reman'd motor from advanced.
Now they are out of sync. It works perfect, just backward.
Ive lowered and raised it manually, and flipped the switch, no luck.i Took the arm off and flipped it, no luck. Unhooked the battery and set them to the same spot, no luck. Done everything i can think of except cut and splice the wires bacwards!!!
Old 12-22-2011, 04:45 PM
unhook the faulty motor, then turn the lights on, wait a few seconds then plug faulty motor back in... maybe that will work... the module doesnt know OPEN or CLOSED.. it just does on function for ON and the opposite for OFF. the module just tells the motors to turn off when they hit the stoppers...
Old 12-23-2011, 01:23 AM
After trying all kinds of retarded ****, i switched the wires on the motor.
I took the connector apart, depinned the two wires for the motor and swapped their places, and reinserted them into the connector.
Problem solved. Works like new.
Old 12-23-2011, 09:16 AM
1SLwLS1's Avatar
Hmm, those harnesses only go on one way. I am guessing the parts store gave you the wrong side headlight motor then? For example, if your driver's side headlight was working correctly but your passenger side wasn't, then the parts store gave you a left motor on the passenger side or vice versa. That's the only thing I can think of.
Old 12-23-2011, 09:31 AM
enigmah's Avatar
It wouldn't bolt up, I tried it. They're backwards from eachother.
Old 12-23-2011, 04:46 PM
Thumbs up Hey
Thanks every1 for helping me with my headlight problem
Old 12-24-2011, 03:09 AM
chrysler kid's Avatar
I had the same problem with the reman motors From autozone. Sometimes they put the motors on backwards.
Have them order you a brand new unit and that will fix the problem
