what plugs?
22psi and 23* of timing on pump? Meth or not that's a lot of timing especially on 6 range plugs. Are you reading your plugs at all? Not just pulling them out randomly, but putting a new set in making a pass, shutting it down afterwards and reading them?
Isn't a br7ef a non projected tip plug? FI is supposed to utilize a projected tip plug from what I have read and heard, and nitrous utilizes non projected tip plugs.
11 Second Truck Club
I couldn't get the BR7's to work in mine. The non projected tip caused low speed misfires and horrible gas mileage. Had the same thing happen with a Lightning I had way back in the day. TR6's are working fine for me at 15lbs, meth and pump gas.
NicD- So when do you know when to use a projected or non projected tip? Is it decided by fuel, psi, timing or compression? Just trying to learn something here, I always used projected tip TR6's.
Here is a good article I found in Car Craft, it's basically saying that projected tip plugs should be used, unless in a high boost racing type application. I guess it all comes down to what you are comfortable with and what you consider high boost, as I don't consider anything under 18-20psi high boost, again what you are comfortable with. I ran meth injection on my car and no more than 14-16* total timing at 15psi and 93/110 fuel. Those that don't want to read it, it basically says that a projected tip will allow timing to be reduced while still giving good or better throttle response with a lesser risk of detonation due to retarded timing. Then it says for nitrous most use a non projected tip plug. It's even saying some/most Top Fuel teams are using projected tip plugs albeit cut down. Interesting read for sure. Kinda what I have heard all along thus why I made the statement I did.
http://www.carcraft.com/techarticles...ips/index.html
