g body wiring
Old 01-07-2012, 09:13 PM
lemkerailroad's Avatar
Default g body wiring
i just recieved a 81 regal today and am starting to dismantle the engine compartment
wiring is the topic of this post
how do i take the 2001 truck 5.3 warness and intergrate it with the 1981 regal wiring harness to get it to power everything properly
pics, forum links, other referance items, i just am having a hard time tring to put this together and am drawing a blank
any help would be great
thanks in advance
dave
Old 01-08-2012, 07:23 AM
Old Geezer's Avatar
Talking ?????
How much of the Regal "stuff" do you want to retain??
Dash? lighting? Key switch? Fuse panel?
I'm doing an 85 El Camel for a customer. I retained the ft body wiring, signals, h/ls, corner lights, etc, wipers, and the rear lites from the kick panel plug back. I also retained the stock column w/ turn, hi beam, horn, key sw.
The dash, a/c, radio, are custom.
I disconnected the thru the firewall connector, and traced all the wires and labelled them. Same thing w/ the rear body harness and the column harness. [I had printouts of the El Camel's wiring, and the American Autowire Hiway 22 panel I put in.] Makes things MUCH easier!
I used Weatherpak connectors at the firewall, and did away w/ the nasty stock connector. [You could use it and take out the unwanted wires.]
BEFORE YOU START CUTTING, GET THE WIRING DIAGRAMS!
If you need more ideas... It's best to call me..
706-342-3152
Old 01-08-2012, 07:38 AM
i am planning on installing the engine harness
for right now i am going to run the stock dash but down the road i am going to switch to a f body dash
i deff will give you a call and i am tring to find diagrams right now
dave
Old 03-31-2012, 03:28 PM
ttt for the weekend guys
i am getting real close to wiring this beast
i need to find out the wiring from the regal
i am having no luck in finding wiring diagrams
i am in need of some help please
thanks in advance
Old 03-31-2012, 06:44 PM
RenoReno2's Avatar
take a look on montecarloss.com under lsx swap in the engine section alot of good info there
Old 03-31-2012, 07:55 PM
t72ss402's Avatar
Default Wiring diagrams
You may try this http://www.maliburacing.com/wiring.html i know that they are for the malibu, el camino, etc... But may still be the same because of GM color code per wiring.
Here is a link for the gauges pin outs, again they are for a Malibu but still may be the same not really sure though http://www.maliburacing.com/gauge_conversion.html
Tim.
Old 04-01-2012, 12:17 PM
thanks guys for the help with the wiring
is their a pic of the bulkhead connector and pi location so i can hook up the wiring
someone had hacked the harness before me to put a v6 blazer set up in it
and i mean it was a hack job
Old 04-01-2012, 12:22 PM
99VetteFRC's Avatar
I made a standalone out of the 03 truck harness and hooked it to my Chevelle hrness with 4 wires and batt cables. Didn't cut 1 wire from the Chevelle factory herness. I did use the old trans and dash. Was very easy and runs perfect.
Old 04-01-2012, 08:41 PM
tta656's Avatar
Smile
i like this...keep posting..
Quick Reply: g body wiring
