what would cause the o2's to be acting like this? (hp tuners chart .jpg)
This almost looks unreal to me, the engine acts very strange when you either drive it, or rev it up past 1k RPM in park/neutral. It sounds like it revs high, then low, then high, then low repeatedly by about 100 RPM very fast
**it runs fine in open loop, but once it goes to closed loop all hell breaks loose**
This is from a 5.3L that was installed in a jeep wrangler. It is ran by a 1998 pcm/harness of a Camaro that was/looks like tuned correctly. I cannot confirm if the front oxygen sensors are from a 98-02 F-body. LS1 injectors were installed on it to work with the harness, I cannot confirm if the tune was set up for them or not though.
What all have you checked so far? With the way the fuel trim looks, it shows that bank 1 is reading rich and bank 2 is reading lean. I never seen data like that before but just saying by the way it looks one side is seeing the complete opposite of the other side. If I'm correct shouldn't the tps be more than 6% over 1200rpm? From what I have messed with before it should be about 6% at idle.
Correct me if I'm wrong I'm jus throwing out some idea but I havent messed with a swapped engine in other vehicle yet. Idk if that should matter in this case or not.
It doesn't have an electronic throttle body, so the TPS % is 0 at idle
I'm about to take the intake off, check over it. I'm also swapping in a 99+ LS1 wiring harness w/ 5.3L injectors and newer PCM
Because the wave pattern is very square and sharp, my guess is something is wired incorrectly. Normally, the O2 sensors will have a sharp zig-zag up and down with no plateaus at the top or bottom. Yours graphs have square wave which is not possible with gases that flow across your O2 sensors. That suggests to me you have a wiring problem.
What if you took the oxygen sensors out of the picture? Disconnect it see what your computer does. I know that's how I knew I had a oxygen problem with mine, it did the same thing but I didn't have a scan tool or dso to look so I just replaced the sensor and got lucky. Does the computer go into open loop again at a certain rpm? I know some do, I know all should go open loop with WOT.
right now I am in the process of taking off the 1998 pcm/harness and swapping in a 99+ LS1 harness and 99+ style PCM. I will keep everyone updated at to if this solves the problem
Unless something is messed up in the internal wiring of the 1998 harness. Such as 1 wire was switch from the main PCM connector. The harness was made by some random person that they tried to sell as a professionally made harness
I swapped the o2 plugs though and it shows the same pattern but just a little more wackier and it revs really bad, where as how it is now it revs, but it's just not a stready rev
Even if it's screwed up wiring in the harness, O2s only report what they see, and it's obvious they are reporting.
I really appreciate the help, I just wished I would have recorded that scan so you could see it (now the wiring is off..)
I forgot that I did get a scan of swapping the oxygen sensor wiring (bank 1 to bank 2, bank2 to bank 1) so everyone can see that crazy data lol
