243's or milled 317's
Old 01-10-2012, 06:32 PM
ksk1980's Avatar
Default 243's or milled 317's
Running a ms3 in a lq4 question is bang for the bucks wise would i benefit more using 243's with this cam or mill the 317's i already have n go a diif cam. This is a m6 4.10 street /strip
any suggestion are greatly appreciated
Old 01-10-2012, 07:00 PM
KCS
Moderator
KCS's Avatar
Milling will reduce your PTV and basically negate the savings of the 317's, so I would lean towards 243's.
Old 01-10-2012, 07:03 PM
JPH
JPH's Avatar
^^^^agree...
Old 01-10-2012, 07:32 PM
ksk1980's Avatar
I know it would running the ms3 just wondering if id be able to get more outta the motor using a smaller lift cam with a lower duration with milled 317'sa since i already have them n a cam is alot cheaper than a set of heads
Old 01-10-2012, 10:08 PM
JPH
JPH's Avatar
228/232 .590/.595 112 profile is what I would steer you towards.
Old 01-10-2012, 10:28 PM
ksk1980's Avatar
Numbers wise how would that cam perform with the milled 317'sa compared to stock 243'sset an the ms3?
Old 01-10-2012, 10:32 PM
JPH
JPH's Avatar
PTV will be the issue with milling the 317s to get the right amount of SCR in the motor and effecting flow at the same time. The 228/232 should produce better torque but lay over buy 6200, where the MS3 should carry further out to the 6400-6500 range and making more hp up top.
Old 01-10-2012, 11:43 PM
ksk1980's Avatar
That was the only thing i kinda didnt like about the ms3 when i had it in the stock ls1 it was dead as 4a oclock until about 23-2500a rpms but made up for it from then on it pulled like a ****.
Im just check options here might end up changing pistons anyways pending on what the clyinders look like when i pull it down
Old 01-10-2012, 11:45 PM
ksk1980's Avatar
Tryin to stay as cost effective as possible here but i know building ls motors aint cheap!
Old 01-11-2012, 01:33 AM
wildcamaro's Avatar
243s are ten times better for that cam, high revving cams like that need more compression which the 243 heads would give you. Only thing I would run 317s on is a turbo/blower motor.
Old 01-11-2012, 01:50 AM
hammertime's Avatar
Your 317's are a good buy for someone looking to go forced induction. That should help offset your cost some. Actually, someone will pickup that MS3 as well if you decide to go smaller.
Milling your 317's limits your potential resale too, aside from effecting your available PTV clearance.
Old 01-17-2012, 12:03 AM
BigMilan312's Avatar
Will this setup be boosted?
Old 01-18-2012, 07:21 PM
ksk1980's Avatar
No boost . NA
Old 01-18-2012, 07:42 PM
Bigredmachine's Avatar
Im actually in the same dilemma. I got a set of 317s for free off of an Escalade LQ9 for free, so I figured you cant beat free and they have the same ports as the 243s. Im in the middle of doing some nice port work to them and after a lot of talking with Texas Speed I am going to run them with a TSP 233/239 112LSA cam. They said it would make great streetable power with these heads even if I didnt mill them, but I planned on putting the cam in and mocking the heads up to measure PTV clearance and milling as much as I can get away with. Ive heard of a few people running more cam and milling 317s enough to get back to 10:1 compression and even a bit more.
Old 01-18-2012, 07:56 PM
ksk1980's Avatar
Yea dont mind milling the 317 heads at all since ive got them n dont hardly have any $ in them. So $400 on a cam sure as hell beats $1500-2000 on a set of aftermarket heads. Especially since my build is mainly just to get the car back on the road n have a play toy with decent power that i dont have to reem the sh@t out of it to enjoy the cam other than an awsome sounding lope
Old 01-18-2012, 08:54 PM
wildcamaro's Avatar
I would run ls1 stock heads before running 317s, those 317s will murder your compression. Ratio which is important if you are cammming it...those cams love compression!
Old 01-18-2012, 09:33 PM
You can mill the 317s to stock or close enough so that it wouldn't cause issue. Obviously there's no set amount you can mill them to be safe as every cam is going to give you different PTV clearance. The only way to surely know is to put the cam in you are going to use with the head gasket and heads in place and see how much clearance you have and then mill them accordingly. Unless your using a fairly large cam your going to be able to get close or the same as stock compression by milling the 317s if you do it right which would definatly be an improvement over the 241s. Would be even better if u went through the heads a little and cleaned them up. And you'll still save some money. Just like you this is the route I'm going as my car is a daily driver looking for more power on a budget. Just getting tired of everyone knocking on the 317 heads. Just do it right and you won't have a problem
Quick Reply: 243's or milled 317's
