FLT Level 4 4L60E 300 shot?
Hey guys, i purchased a used level 4 4l60 from a friend of mine. He said it was built by FLT and it has roughly 15k on it. i was wondering if it will handle my setup, i have a PY3600 converter and 3.73 gear and i make 420 rwhp and 400 rwt N/A. im not sure what it will make on spray yet but i am planning to spray a 300 shot. do i need to worry about my trans or the input shaft? thanks for the help guys!
So I would give them a call, and don't be surprised if they try and steer you towards a more robust tranny.
good luck making a 4l60 of any level last at anything over 550-600 horsepower...
and even that is pushing it in my opinion...
not saying it cant take it for a little bit...but its certainly not going to last long
you really need to step up to a 4l80 or a th400 when you get to that point...
and if you are a heavy car....it better be a pretty well built 4l80.
I've been ruining a 4l60 for 7 years and if it was a big problem I would have switched by now.. and my car's a little heavy and a little fast
Also, about the 4l80e thing, there are guys here that have taken stock 4l80's in stock form with a shift kit and are running well into the 9's.
A FLT built 4l60e should never fall into that general rule of thumb that a 4l60 cants last with any power. Those guys know what they are doing. Ive been running their level 7 for a couple years with a trans brake and anywhere from 600whp to now almost 800whp,no issues at all with it. I think they are going to recomend you get billet input and output shaft and some new updates they have come up with in the last year.
First thing I would do is speak with Andy @ FLT he will point you in the right direction.
I run a level 5, I drive it daily and spray a 175 shot on mine and I make about the same power on motor as you and so far it hasn't skipped a beat after almost 2 years. The only reason I haven't sprayed more yet is because I have been working on the 60ft. Once I get the car to work, I will be stepping up the jets.
In the end, you have to think about what you're trying to do, and your end goals. A well built 60 has gone fast in many different cars, but it does have its limits. I think you will end up wanting to upgrade the output shaft to billet and send it back to FLT for any updates and a refresh especially since you got a good deal on that unit.
the only problem with that is i already have the trans in the car because its the only car i have.
i called FLT and spoke to someone but im not sure who it was, they didnt give me a straight answer they said "it would handle a lot, we cant really rate out transes by horse power"
What I would do if I were you is start with a smaller shot first. Say 150hp, get the tune down right, and see how the trans reacts, and how fast you go. If all goes well, move up another 25-50hp and see how it goes. etc. etc. I'm not sure what you're goal is, but I wouldn't start with a 300 shot from the beginning.
