truck pcm w LS1
Old 01-21-2012, 10:12 PM
jojomanx's Avatar
Default truck pcm w LS1
I need some help.
I have an LS1 in a Porsche with truck PCM and harness.
I have upgraded the PCM to LS1.
The engine starts and runs for 3-5 seconds.
I have switch the TPS, ICV and a AFM from a running vehicle.
No changes. Starts but does not run more than 3-5 seconds.
Where should I start looking?
Old 01-21-2012, 10:23 PM
jojomanx's Avatar
Also new are the MAP sensor, coolant temp and intake temp sensors.
Only using foward O2 sensors.
Old 01-22-2012, 12:45 AM
MontecarloDrag's Avatar
Is VATS disabled in the tune?
Old 01-22-2012, 08:32 AM
jojomanx's Avatar
It should have been! I will ask.
Old 01-22-2012, 08:54 AM
jojomanx's Avatar
So VATS will allow the engine to start but not run? I thought it would have dissable the start from the beginning!
Interesting!
Old 01-23-2012, 06:48 PM
10-e-c-350z's Avatar
correct.
Old 01-23-2012, 07:02 PM
Interesting!
You know VATS is enabled when engine starts but dies.
I have done several swaps and they always do that, start and die. A few only crank and don't start.
Old 01-23-2012, 07:17 PM
jojomanx's Avatar
Default thanks
thanks!
Next week the tuner comes over and Im sure he will see it.
thanks again
Old 01-30-2012, 11:20 AM
jojomanx's Avatar
anybody have a 2003 truck print? Or pcm pinouts?
Old 01-30-2012, 02:42 PM
Which truck?
Old 02-01-2012, 08:07 AM
jojomanx's Avatar
I believe it was a 2003 4.8 harness and pcm.
Old 02-01-2012, 11:36 AM
rojs234's Avatar
Try going to www.lt1swap.com . They have the 2003 truck pin outs (among many others) and it's free. Great site!.
Ron
Old 02-02-2012, 07:35 AM
jojomanx's Avatar
Default question
Isn't there a inline resister that I can bypass in the Harness?
Old 02-02-2012, 08:48 PM
These are the PCM pinouts from a 2003 Avalanche. They are the same as the 4.8L.
If the PCM/engine came from another truck, there may be differences but only a few.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old 02-03-2012, 01:32 PM
01WS6/tamu's Avatar
The VATS must be disabled via a tuner only. On trucks the VATS run command is via the databus from the trucks bcm. It does not have a hardwired vats circuit..
Old 02-04-2012, 08:46 AM
jojomanx's Avatar
Default solved
We found out what it was! Tuner never flashed in VATS.
610 PCM can not be used on manual cable trottle bodies. Only on drive by wire TB's.
411 boxes are for manual TB's. We switched boxes and BINGO!
Porsche 928 w LS1 has started up and will be on the road as soon as we can get a plate on it.
Thanks guys for everything!
Old 02-04-2012, 08:54 AM
jojomanx's Avatar
THANKS FOR THE COMPLETE PRINTS!
PICS AND VIDEO SOON!
HEANWHILE CHECK MY LS1 BMW OUT!
http://youtu.be/6UNDSKCguqc
