Good option? L76 w/ 243/247 .621/.612 114+3?
Looking at buying a used cam from a member.
Picking up a L76 sat and will be removing VVT and AFM. (May add VVT back later) So L92 heads which I may have the exhaust ports ported a bit since I hear thats where they could use some help.
Cam is 243/247, .621/.612, 114+3 LSA
Good option?
Good option?
For now I will keep my eyes pealed for a used one. The one I originally mentioned is$230 shipped. Seems about the range I've spent in the past.
To big. I run a smaller cam in my 418 l92. I used to run a cam a little bigger than that and the driveability sucked. Went to a smaller grind and picked up power and driveability.
LS1Tech Premium Sponsor
We have several camshafts that have been proven in similar applications. Although, if you are still interested in going with a custom grind, we can spec you one out for $389.99.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
comp is a joke. They have no idea about cam specs for these heads. Comp likes to overcam the l92/ls3 combo's. Saw an article awhile back where comp spec'd some 25x/26x cam on a 408 with ls3 heads. Made like 580 or so flywheel hp if i recall. I made more with way less overlap. Need to keep the air speed up with the huge rectangular ports.
