84 c-10 ls swap
Old 01-27-2012, 06:54 PM
ls-won-84c10's Avatar
Default 84 c-10 ls swap
i wana talk with someone whos done an ls swap on a 73-87 model 1/2 ton c-10 trucks, im curious about headers and what will fit, what wont fit, or should i get some built? can someone help me out?
Old 01-28-2012, 07:32 AM
anyone?
Old 01-28-2012, 11:43 AM
dec010974's Avatar
Default 87 c10 5.3/4l60e swap
hello ls1tech. In response to your answer, ive completed the swap. ask away. I used s&p adapter plates, corvette fuel filter regulater, electric fans, current performance fuse box, jba shorty headers, notched my frame so the jba headers could fit, ep381 fuel pump inside the tank, & friend with hp tuners removed vats to use stock pcm.
Attached Thumbnails 84 c-10 ls swap-87-c10-lm7-swap-002.jpg   84 c-10 ls swap-87-c10-lm7-swap-004.jpg   84 c-10 ls swap-87-c10-lm7-swap-005.jpg   84 c-10 ls swap-87-c10-lm7-swap-003.jpg
Old 01-28-2012, 11:48 AM
dec010974's Avatar
Default 5.3/4l60e swap
sorry for the unfinished engine bay. rite now my job has me super busy and i havent had time to reorganize the wiring. to note my swap is road worthy. i have 5000 swap miles, including (1) turkey run road trip.
Old 01-29-2012, 04:42 PM
Default swap
nice job man, thanks for the info
Old 01-29-2012, 06:31 PM
Jbabycsx's Avatar
From what I have found, the Schoenfeld 88+ headers will work in our body style as well. I just ordered mine last night.
Old 02-01-2012, 12:21 AM
Default headers
please let me know how they work for you, thanks !!
Old 03-14-2012, 04:02 AM
gordonr1973's Avatar
I used S&P headers. They fit fine but I will notch my frame by about a 1/4" just to make sure one tube won't hit the frame.
One tip, the collectors need to be bolted on the headers before the headers are installed or you will never have room to reach in there with a wrench.
Old 05-17-2012, 10:30 AM
kainedogg's Avatar
I have an '84 and sent you a pm. What kind of radiator and electric fans are you using. Was going to use the stock radiator and Windstar fans.
Quick Reply: 84 c-10 ls swap
