Torquer V2 or V3
Torquer V2 or V3
I was set on one of these cams but after reading the link below I am worried it may be too much cam. I want something that isnt going to lose power down low. I plan on running the stock heads because I dont want to spend alot of money. My goal is to break into the high 11's after a tune
http://www.ls1howto.com/index.php?article=23
I was thinking of keeping the heads stock because I dont want to replace the clutch and 10-bolt. If I just get the TV2 cam I can get away with keeping them stock.
It gets expensive because its about $800 for the cam/springs, probably $500 for labor and another $500 for a tune. Not sure if I want to put more than that into an older car ya know?
The Tv3 is has better low end than the tv2 and has same mid n top or better. Its been explained by TSP many times on this board FYI. About the size, they're identical or so. Higher lift doesn't mean bigger cam at all, you just need better and more expensive valvesprings. Get the tv3 unless you want to save on valvesprings. No it doesn't need more maintenance, It's not even really true for mechanic roller setup.
My 700$ stage 3 monster clutch will hold any clutch dump, even on the juice N/A you will be fine
I put a V3 in my 6.0 with TSP 215 cnc ported heads. On the dyno it shows that it comes on around 2500 and pulls hard across the RPM range. I actually feel it by 3000rpm, and runs good.
I would suggest the V3 but not sure if your heads can flow that?
why are you dead set on these two cams?
i have seen a stock head LS1 make 400rwhp with the Torquer V2 plenty of time with the right supporting mods and good tune. but i would consider a more modern lobe cam such as the LSL lobed LSR cams. they are softer on the seat which saves your valves, springs and brings the valvetrain noise level down
any modern lobe cam in the high 220's low 230's these days will get you that. i love my cam and it is a 227/235. i have great low end power and outstanding top end with a advertised operating range from 1900-6600. i can drive this thing all day and feels like more power all over. the cam pulls hard to around 6500 with a shift point of around 6600-6700.
