4.10 gear and 28" tall tires..... Will I run out of gear?
Old 02-02-2012, 08:22 PM
Dave_the_SS's Avatar
Default 4.10 gear and 28" tall tires..... Will I run out of gear?
I have a 2000 SS A4 with following mods
Lt's
Ported tb
Lid
True duals
Ms3
3600 stall
And spray.
28" tall DR
Currentley the car has stock 3.23 gears.I run a 325/50/15 out back. I was told that due to tire size my 3.23 was really like a 2.98 gear.
My tuner said to get 4.10's which with my tire would be about a 3.65 gear.
My qusetion is what would it put my rpms at when doing 65-70 mph?
Will I run out of gear in the 1/4 mile if I spray?
I do daily drive the car.
Old 02-02-2012, 08:25 PM
John Deere racer's Avatar
I think it b more like a 382 gear
It prolly b to much gear for spray
Old 02-02-2012, 08:30 PM
So would u suggest a 3.73 gear or a 3.90?(if u can get a 3.90 for a 10 bolt)
Cause I am still on a stock 10 bolt. And that's why I didn't change gears is to keep the bigger pinion gear of my 3.23'
Old 02-02-2012, 08:34 PM
guppymech's Avatar
There's a good gear calculator at f-body.org You'll be able to look at speed vs rpm in 100 rpm increments.
http://f-body.org/gears/
Old 02-02-2012, 08:36 PM
tt383lt1's Avatar
what tranny a 3 speed. and i got a th400 and i just had 4.11 with a 28" slick and it screemed at 65 to 70 and i talked to alot of people on this forum and others forums told me to run a 3.25 so thats what i just put in.
Old 02-02-2012, 08:37 PM
kidcamaro98's Avatar
I have a ms3 with nitrous on a 28" nitto with a 4.11 gear but im a T56
Old 02-02-2012, 10:23 PM
ssfast99's Avatar
Im with Kidmaro, at 600rwhp on spray with 27" tires, 4:10, and a T56 i was out of gear but also ran 132mph too. If you are planning on running faster than that then move to a rear 3:90 gear, which is better for DD anyways.
Yes you can get a 3:90 in the 7.5 gear set series.
Old 02-02-2012, 10:28 PM
BOLO's Avatar
Lt's
Ported tb
Lid
True duals
Ms3
3600 stall
And spray.
28" tall DR
I ran a 150 shot. 4000 stall, 4.10 gear(stock 10 bolt) and 325/50's @ about 6500 rpm at the traps. Plenty of head room.
Old 02-03-2012, 01:00 AM
what was your ET and mph just curious?
Old 02-03-2012, 10:35 PM
im running 600rwhp as well on a 150 shot. I had a 26" MT on there before and spraying the gears werent long enough for me, so I stepped up to a 28" nitto and its much better.
Old 02-04-2012, 12:02 AM
BOLO's Avatar
10.4@130 w/ a 1.53 sixty
Old 02-04-2012, 07:26 AM
zracer323's Avatar
You news to figure out your converter slip percentage to determine your rpm. That calculator assumes a locked converter. tci.com has some calculators that include converter slip into their calculation. Keep in mind you converter will slip more when sprayed.
Quick Reply: 4.10 gear and 28" tall tires..... Will I run out of gear?
