Stock turbo 5.3 9.80s MP76....... S475
Old 02-02-2012, 10:31 PM
Transam Rocket's Avatar
Default Stock turbo 5.3 9.80s MP76....... S475
I looking to run some 9.80s in the 1/4 in my 02 camaro
Has a 5.3 lm7 stock 706 heads, victor jr manifold
Ls6 cam, truck manifold turbo kit, intercooler, meth injection, and e85
Stuck on what turbo will take me there? Thinking about a s475 or s480 t6
Wieghs about 3400 has a 4l80e 3600 stall and 2step need your help..... Thanks
Old 02-03-2012, 06:14 AM
LS1NOVA's Avatar
I havent personally done this yet but have done some research on it. If all your concerned with is the drag times then get the S480. If you want the 9.80's and superior street manners and quicker spool then use a PTE 7675 (older ones are called 76GTS).
Old 02-03-2012, 06:59 AM
1fast bird's Avatar
I would do the pte 7675 for faster spooling. Would be a great match for the 5.3 and would easy go 9.80's.
Old 02-03-2012, 08:25 AM
Orr89rocz's Avatar
3400lbs with boost off the line (you have a tbrake or just a 2step?) you should beable to get there with either 475 or 480. 480 give abit more margin/growth in case you change goals.
With a great 60 foot you only need about 135 mph at that weight which is about 550whp. My friends 4th gen at around 3400lbs goes 132 all motor with 521whp. Ok 60 foots you'd need abit more power to get there. Then again, where you located and whats the typical weather like? DA at the track? Makes a huge difference.
My car left all motor and ran 9.8s but at 141mph. 60 foots were in the lazy 1.5x-1.60 range 3550lbs estimated with 650whp on a stingy mustang dyno, so figure 700-725 on dynojet. 475 will cover that power.
Old 02-03-2012, 09:41 AM
Thanks guys im goin to try the s475 what a.r should I get? 1.32 or 1.10 both t6
And then save up for the pte7675 turbo does anyone know were I can get a good deal new or used? Also its a two step for now, till I get my trans brake.....
Old 02-03-2012, 09:46 AM
Also the track is sacramento raceway DA is like 32ft temp in the 60s at night
Old 02-03-2012, 10:31 AM
drumbo87's Avatar
Talk to the guys at forced inductions, maybe they can make some suggestions possibly their st80?
Old 02-03-2012, 10:52 AM
Thanks will do
Old 02-03-2012, 11:47 AM
What tubo would be best the s475 83mm with 1.10 a.r or the s475 96mm 1.32a.r for my goal 9.80s also Will be doing a couple of street pulls
Old 02-03-2012, 01:07 PM
Hank Peabody's Avatar
s475 83mm turbine t4 is very comparable to a PT7675 spool and capabilities wise, s475 96mm turbine is a much bigger turbine
Old 02-03-2012, 01:31 PM
So a s475 83mm should do just perfect then....
Old 02-04-2012, 12:03 PM
831jd's Avatar
[QUOTE=LS1NOVA;15919485]I havent personally done this yet but have done some research on it. If all your concerned with is the drag times then get the S480. If you want the 9.80's and superior street manners and quicker spool then use a PTE 7675
Old 02-05-2012, 07:38 PM
LS 69 camaro's Avatar
hi guys what makes the pte 7675 spool so much better in street driving vs the s480.will they both make the same power or because the pte 7675 spools faster sooner it would make it run better in the top end.what kind of power are these turbos capable of out of a bone stock 5.3 with a real good tune and the right fuel and inner cooling?any info would be great
Old 02-06-2012, 03:27 PM
LS1NOVA's Avatar
Basically the S480 is a big heavy unit with larger everything and the PTE unit is small/light with the latest wheel technology and smaller turbine/ AR. Think of it like a set of light forged drag wheels/tires versus and set of heavy cast wheels when accelerating.
The 7675 is capable of near 900rwhp pushing to the limits. Not sure how far anyone has pushed a S480 on a 5.3. The 5.3 really needs a little cam to wake it up though as the stock one is tiny. (you mentioned bone stock)
Old 02-06-2012, 05:20 PM
00Wildcat's Avatar
Dan at dtmmotorsports.biz took care of my precision needs. Great guy to talk to and had everyone else beat by 10% or more
Old 02-06-2012, 06:48 PM
PRAY HRD's Avatar
i'd be very careful of posting a non'sponsor up like that! good way to get the boot unless they are a sponsor i haven't heard of yet.
Old 02-07-2012, 01:09 AM
would a master power t76 ar 1.0 be able to push it too 9.80s my buddy selling one cheap?
Old 02-07-2012, 02:57 AM
Fbodyjunkie06's Avatar
they make a 87mm turbine in that s400 chassis turbo also.
Old 02-14-2012, 11:37 AM
T76s10's Avatar
I don't see why the t76 wouldn't bring you into the 9's. Parish did it with a t70 but his fairmont was probably 600 pounds lighter than your f body
Quick Reply: Stock turbo 5.3 9.80s MP76....... S475
