big stuff 3 /lsx 7000 + rpm
just wondering who is using bigstuff 3 with lsx soild roller big rpm 8000 9000 ..what are you guys doing to measure crank signal ...like sensor /reluctor wheel ..front or back ..i been good to 7200 ..not so sure the signal will be good past that
LS1 Tech Administrator
The guys I've seen running over 8000 rpm have typically gone to a distributor and a Jesel belt drive. I'm sure there are more ways to skin a cat though.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
There seems alot of debate on this topic.
Our experience has been:
stock pcm shuts down around 8200+
bs3 with internal cam/crank gm ls7 block worked to 9000rpms with COP and no belt drive
We have seen a steady signal to 9500 rpms on the dyno with bs3 external reluctor/belt drive/ and COP.
Others have had a different experience. No 2 setups are equal so do your research and make an informed decision from a large sample of information.
3 options now front mount reluctor with sensor 70/30 chance !!! big stuff owner tells me #1. .rip out block change reluctor on crank to ls7 covert all big stuff send in bigstuff $$ #2 or roll the dice my power falls off at 7200 rpm .#3 ..i dont like my options on all these
Processor Speed vs Tooth Count
I have heard that John M. states the same thing about his BS-3, NO high rpm with the 60-2 (58-x) TW.
My ECU-882 family will run over 25K with a 58x (60-2) crankshaft Target Wheel.
The common knowledge is derived from processor speed vs tooth events.
Industry standard is 100mhz for the 60-2, the 164 he uses is 25mhz.
Thus when shopping for a system, check for processor speed.
Lance
Lance
Lance
Lance
