New LS7 Build
Old 02-05-2012, 11:56 AM
flash911's Avatar
Default New LS7 Build
So I’ve been lurking over here for about a year, learning as much as I can from you guys. Now that my motor is about done, I wanted to post some details and get your feedback. I’m no LS pro by a long shot and still learning as I go.
A little background….me and a few buddies hang out here to figure out how to build strong LS motors to stuff into our retro cars. Mostly used for AutoX and time trials, we attend local track days, SCCA/NMCA and Streetcar events. These events are formerly called ‘Run To The’ (RTTx) events, such as Run to the Hills, Run to the Coast, etc. They are now rebranded as American Street Car Series (americanstreetcarseries.com). Most of us hang out at Protouring.com or Lareral-G.net. For the most part the motors are built not for drag racing 8k top end, but more for fast revving in-n-out of corners torque. My goal was to build a bullet proof (no such thing!) LS7, or at least take out some of the documented weaknesses. I started w a flea-bay motor some knucklehead built wrong. I bought it knowing I would tear it down and rebuild it as strong as possible for the planned abuse. Last thing I wanted was a rod grenading the side of the block or needle bearings falling through the rotating assy under power. I wanted it to breathe good, accelerate quick and rev to 7k on the straights. I didn’t sleeve it, although I did speak to RED Steve and one day I’ll beef up the block a little (meaning the motor will be rebuilt at some point, planned or forced).
According to Ovrkill, here’s my ‘puny’ motor (hey Brent!). All the work was done at QMP Racing in Chatsworth, CA. I’ve known Brad and Mikey for a loooong time and consider them friends. These guys really know their stuff and everything is done in house. On any given week you’ll see small blocks, big blocks, turbo/blower builds, a Lambo rebuild or one of those Sonny-whats-his-names 800 cu alum motors! That thing is huge BTW…
I started w a stock GM LS7 crate motor. Block was CNC blueprinted, diamond honed, decked, align honed, Cam tunnel bored. We balanced the factory forged crank and added Crower billet steel connecting rods, ROSS custom pistons and pins, and a set of Total Seal custom rings. ARP main bearing studs hold it all together. I’ve got a 13 lb Fidanze alum flywheel and a McLeod RST clamp I’ll throw on when the time comes.
Heads were fully prepped w CNC port to breathe 390 cfm @ .0600. Milled and given their competition valve job. We kept the Titanium valves and added Manley Titanium spring cups , retainers, pushrods and polished valve springs. CHE bushed rockers help delete those pesky needle bearings. We also used some of those new Comp short throw lifters (tray type) to see if they truly help the motor build revs faster and control any valve float.
Tieing the two together is a Comp bump stick. 235/244, 630 lift w a 113+2 LSA. Brad cam doctored it as he always does and this is the formula for my intended use.
For oiling I’m using an LS9 pump, Avaid pan baffle, Peterson baffled tank and breather. These cars don’t quite pull like race prepped Vetts so I think I should be good.
Up top I’ve got a Mamo ported factory intake, Fast rails and a BER ported TB. We threw a set of Fast flow matched injectors pumping 65 psi just in case I decide to add some cubes or something later on down the road.
Here's some pics...
Old 02-05-2012, 12:15 PM
3.8redbird's Avatar
What car is this going into? Nice motor.
Old 02-05-2012, 02:37 PM
flash911's Avatar
Thx man. 69 Camaro...
Old 03-02-2012, 12:44 PM
slowlaneblues06's Avatar
Looking at an LS7 build myself. Why the additional block prep? I have asked Scoggins dickey and GMPP, the blocks are supposed to be RTA.
And what are the needle bearings you are referring to, from cam bearings?
Old 03-02-2012, 05:48 PM
Jimbo1367's Avatar
What does "RTA" mean? I think he was referring to the stock rockers failing and the needle bearings going through the motor
thanks,
Jim
Old 03-02-2012, 10:20 PM
flash911's Avatar
thanks,
Jim
Correct Jimbo - stock rocker needle bearings.
No idea what he was referring to w 'RTA'. IMO extra block prep = tighter tolerances for a better running motor under harsh conditions. I'm no machinist but barrels do get off center (I'm told) so CNC blueprinting helps for a good starting point.
Old 03-03-2012, 10:32 AM
helicoil's Avatar
RTA - Ready to Assemble?? Nice looking motor.
Old 03-04-2012, 02:21 AM
flash911's Avatar
Thank you Sir
Old 03-04-2012, 09:05 AM
Pumba's Avatar
I started with a stock GM LS7 crate motor. Block was CNC blueprinted, diamond honed, decked, align honed, Cam tunnel bored. We balanced the factory forged crank and added Crower billet steel connecting rods, ROSS custom pistons and pins, and a set of Total Seal custom rings. ARP main bearing studs hold it all together. I’ve got a 13 lb Fidanza aluminum flywheel and a McLeod RST clamp I’ll throw on when the time comes.
Here's some pics...
Congratulations on you new engine.
I have three immediate items that I hope you will consider before you finish the assembly of the engine:
1) Send your pistons to Andy Suman at Line2LineCoatings.com along with your finished bore diameter, and have him coat the skirts.
2) Order a set of Smith Brothers oil flow restricting 3/8-inch pushrods.
3) Replace your LS9 oil pump with a Melling 10355 oil pump.
Good luck with your new engine.
Old 03-04-2012, 09:48 AM
SHovV's Avatar
how much street time will this motor/car see? awesome build
Old 03-04-2012, 11:05 AM
lazaris's Avatar
Does the 10355 pump have any cavitation problems above 7500 rpm?
Old 03-04-2012, 11:16 AM
Pumba's Avatar
The tests on these pumps stopped at 8,000 rpms. I have no data above those pump speeds.
Old 03-04-2012, 05:10 PM
flash911's Avatar
^^ Pumba much respect as I think you're a smart guy. But...
* The engine is assembled and I'm not tearing it down to coat the skirts. VERY good suggestion though and something I talked about at the beginning of the build.
* I'm using Manley Pushrods. Prob could've done better but I'm ok w a good brand. I plan to work w the builder to ensure the motor is acting as it should.
* I'm running a modified factory style dry sump. Spoke to Aviad and Katech before I went this route for my intended use. The LS9 scavenges 30% better than the LS7 style.
I'm the first to admit I could've spent more research time on this build, but I think we did ok. This motor will see a phase two as part of it's care and feeding...
Sunday driver + events. Thx for the props!
Old 03-04-2012, 05:23 PM
flash911's Avatar
Quick question - what do you guys think of the Comp short throw lifters? I got the tray type and don't expect to rev the motor past 7200 (right). According to Comp and the builder, these lifters help reduce valve float and make the motor rev faster, kinda like a soild roller. Any opinions on that?
Old 03-05-2012, 07:01 AM
Pumba's Avatar
The COMP short-throw hydraulic roller lifters are a very good item:
But, you need an adjustable valve train in order to get the preload set correctly.
You have C.H.E. trunions in stock rockers, so you would need to adjust preload via pushrod length. Remember if you decide to use them that your block grows 0.012 inches from 70 degrees F to 190 degrees F. That growth will affect your preload.
Old 03-06-2012, 11:33 PM
CAMSTER's Avatar
Default Black tie...
I used a set of the short travel hydraulic roller lifters about a year back and found the following;
The lifter where scraping the lifter bores and the filings where falling on the lifters wheels and the cam, this was rather aggressive by the way, so i removed them and deburred, and polished them, sense the set i got was ruff.
You will need a set of adjustable rocker arms, sense the max crush is .010, and that's not mush.
If the set you have are polished and deburr, you should not have any problems.
Old 03-07-2012, 08:07 AM
Yes, Ready To Assemble.
Nice build. May I ask why skirt the pistons, does it help with friction to rev easier or longevity.
Old 03-08-2012, 01:34 AM
yonerhottlt1's Avatar
Thing of beauty!!
Old 03-08-2012, 02:54 PM
Pumba's Avatar
Yes the Line 2 Line coating of the piston skirts reduces fricition. It also squares the piston in the cylinder and improves ring seal.
Old 03-09-2012, 06:36 PM
LPE 403's Avatar
Originally Posted by yonerhottlt1
Thing of beauty!!
Think this is pretty? You should see what it's goin in!
Quick Reply: New LS7 Build
