Oil pump and Timing Chain Question
Old 02-23-2012, 05:41 PM
Austinma62's Avatar
Default Oil pump and Timing Chain Question
Should I go with the ported LS6 oil pump and LS2 Timing chain set or the SLP oil pump timing chain package? The LS6 oil pump and LS2 tc and about $280 while the SLP set is $350. These parts are going on an LS1 with 124k and future heads and cam swap. What do you guys recommend?
Old 02-23-2012, 05:42 PM
Austinma62's Avatar
All those parts are from TSP.
Old 02-23-2012, 07:24 PM
3rdCoastPowerSports's Avatar
the cheaper route. if the pump is brand new and the chain is new your good to go. your not going to break it
Old 02-23-2012, 07:27 PM
RARON455's Avatar
Ton of guys out there running the ls6 pump from TSP and the ls2 chain with no problems, You will be fine.
Old 02-23-2012, 08:25 PM
Austinma62's Avatar
Yeah, all the parts would be new from TSP. Thanks guys.
Old 02-23-2012, 10:43 PM
wildcamaro's Avatar
Ls6 pump and ls2 is the way to go! I got both mine "slightly used" for $80 and they have worked perfect as did the set I bought brand new! GM parts are reliable!
Old 02-23-2012, 11:45 PM
KLRS10's Avatar
So are talking about getting the ls6 ported oil pump? I am looking at getting an oil pump for my 6.0. But I don't know about getting a oem ls6 pump or a ported high pressure.
Old 02-24-2012, 12:32 AM
wildcamaro's Avatar
Either one will work fine, a high pressure is overkill in my eyes unless you have a serious cubic inch or high revving motor...I run stock ls6 pump on h/c/I no problem. I'm sure the ported ones are nice though.
