Stock motor mount / LS adapter plate issue
Old 02-26-2012, 01:19 PM
-Q-
-Q-'s Avatar
Default Stock motor mount / LS adapter plate issue
I'm sure I'm missing something obvious here, but I went to bolt my stock '75 Corvette motor mounts to the Dirty Dingo adapter plates I'm using for the LS1 conversion, and they won't mount flush to the plates. There's a small hump on the back of the stock motor mount that hits the adapter plate, and it leaves a small gap between the two. No way it is supposed to be like this...
What am I missing? Did you guys have to shim the stock mount with washers?
Here's a pic...
Old 02-26-2012, 02:09 PM
Stormed_Norm's Avatar
Yes, some of them use a washer for a spacer.
Old 02-26-2012, 02:27 PM
-Q-
-Q-'s Avatar
Alright thanks. Just wanted to be sure it wasn't an "operator error" issue.
Old 02-26-2012, 03:26 PM
99VetteFRC's Avatar
I actually used 2 washers with my solid mounts which are flat.
Old 02-26-2012, 07:44 PM
flywheel's Avatar
Bench grinder fixed mine. No washers needed.....
Old 02-26-2012, 08:06 PM
bczee's Avatar
I would either cut the bump off or machine a matching hole in the plate. ( I did the machining).
Old 02-26-2012, 08:08 PM
-Q-
-Q-'s Avatar
I'm glad to see this is a common issue. I searched around a little and couldn't find anything, and thought I was all jacked up...
I ended up buying some new poly motor mounts for the car. I figured I probably should anyways, instead of reusing the ones that are 37 years old. New ones have flat backs, so no worries now.
Old 02-26-2012, 08:21 PM
99VetteFRC's Avatar
I will get some pics of my motormounts and post tomorrow evening.
Old 02-27-2012, 05:33 PM
66chevelle510's Avatar
easiest to just grind it down.
Old 02-27-2012, 07:36 PM
99VetteFRC's Avatar
Sorry no pics.... camera died.
Old 02-27-2012, 09:35 PM
Hodge's Avatar
I am doing a 73 Vette/LS1 and using Dirty Dingo adapter plates. Actually put them on the engine yesterday. My adapter plates have slots to clear the dimple in the motor mount. They fit nice and flush.
Old 02-28-2012, 09:59 AM
-Q-
-Q-'s Avatar
We must have bought different plates. Oh well, the new motor mounts should do the trick for me.
Old 02-28-2012, 07:50 PM
99VetteFRC's Avatar
Well this is how I got the engine mounted in my car. I didn't have access to a peice of metal to make a spacer out of so I stacked washers and welded them into a spacer. It looks kinda hacked but it does work.
Attached Thumbnails Stock motor mount / LS adapter plate issue-dscn1164.jpg   Stock motor mount / LS adapter plate issue-dscn1166.jpg
Quick Reply: Stock motor mount / LS adapter plate issue
