Victor Jr. intake manifold cracked!
Old 03-04-2012, 12:51 PM
Stabbinstevem's Avatar
Default Victor Jr. intake manifold cracked!
I was cleaning it up for my current build project and found this. Has anyone seen this before? 4 of the runners are cracked.
Old 03-04-2012, 03:45 PM
jlcustomz's Avatar
May try consulting Edelbrock tech about it, since that shouldn,t happed. As far as repair goes, it could be tig welded. Crack must be v-grooved & area perfectly cleaned.Tig weld must be hot enough to properly take & not fail, which can be assisted by a mix of helium with the argon gas.
Old 03-04-2012, 03:59 PM
Old School Heavy
speedtigger's Avatar
That is a rather odd place for a crack. Not much load stress there.
Does it go all the way through? If not, I would probably just throw some epoxy in there and go.
Old 03-04-2012, 06:53 PM
farmington's Avatar
were the heads milled a lot and intake side not milled ?
Old 03-04-2012, 08:59 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Happened to me
https://ls1tech.com/forums/generatio...jr-intake.html
Old 03-05-2012, 06:57 PM
The engine was a completely stock 5.3. It looks like the casting was actually milled paper thin on the opposite side where the gasket groove is at. I have always used edelbrock stuff because of the high quality but this intake manifold has me wondering...
Old 03-05-2012, 07:08 PM
Old School Heavy
Originally Posted by Z28/2002
Damn. No epoxy is going to fix that. LOL
Old 03-05-2012, 08:40 PM
Z28/2002's Avatar
I wasn't even going to try, it was a casting issue. lol
It was torqued to spec with brand new Fel Pro gaskets and I noticed it about a year after the fact.
Old 03-05-2012, 09:00 PM
I have had the intake for at least 6 years so i know that Edelbrock is going to say screw me about any kind of warranty. I will just weld it. Probably wouldn't be an issue N/A but it's a turbo truck.
Old 04-30-2013, 02:03 PM
busta9876's Avatar
found this last night on my 89 caprice turbo 5.3L. It developed a loud knock noise. Found a fresh broken piece from the intake, smashed on top of the piston in #7.
Attached Thumbnails Victor Jr. intake manifold cracked!-2013-04-30_13-13-47_881.jpg   Victor Jr. intake manifold cracked!-2013-04-30_13-14-00_591.jpg
Quick Reply: Victor Jr. intake manifold cracked!
