5.3 ho build whats needed to make it solid?
Old 03-12-2012, 12:57 PM
fotoboy's Avatar
Default 5.3 ho build whats needed to make it solid?
THe build is a 5.3 ho w 23,000 miles.
It will either be 317 high compression ported heads 11.2 comp
or
317 stock w new patriot springs. 9.5 ish compression
cam specs: 228 232 594 574 114 lsa
Ported Fast 92 current or going to a TPIS prepped ls6
Procharger P1sc
E85 and a 91 oct tune ( have hp tuners)
Im wanting to get around 600 + whp through a m6
What wound you guys do to keep this motor solid?
Old 03-12-2012, 02:01 PM
wildcamaro's Avatar
With the supercharged I would normally go with the 9:1 comp but since your using e85 I would go with the 11.2:1 for more power
Old 03-12-2012, 03:16 PM
King Nothing's Avatar
9.5:1 would be fine with an iron block but if you have aluminum then 9:1 to be safe on pump gas
Old 03-12-2012, 05:25 PM
fotoboy's Avatar
not running pump. Most of the time it will be corn. Just getting a pump tune in a pinch
Old 03-12-2012, 06:24 PM
mpatton's Avatar
E85 will be fine with high comp. No need to go down to 9.1 at all or even 9.5
Old 03-12-2012, 09:45 PM
garygnu's Avatar
you will need big injectors and a hi volume pump.
Old 03-13-2012, 03:01 AM
fotoboy's Avatar
I have 80 lb, a bap and racetronics rewire
stock with out the above got me 575 whp on e85
Old 03-16-2012, 02:34 PM
chrisfrost's Avatar
A Melling oil pump
Old 03-16-2012, 05:27 PM
conan's Avatar
or
Procharger P1sc
Are you going to bore the block or stock cubes ? If not, 317's are going to drop your compression way to low for street driving. I'm around 9.4:1 and next time I build a motor I'm going to shoot for 10:1 compression. The car is not as snappy out of boost as it was with stock compression. If you are going to forge the rods/pistons and tune it on corn you'll have no problems at 10:1 compression.
Quick Reply: 5.3 ho build whats needed to make it solid?
