Smoothed Truck Intakes
Old 03-13-2012, 09:42 PM
99VetteFRC's Avatar
Default Smoothed Truck Intakes
I am using a truck intake on my swap. I have an extra I was thinking about smoothing out. I used the search but only found pics of one. If anyone has done this I would appreciate some pics.
Old 03-13-2012, 11:18 PM
2baditsnotachev's Avatar
Looking forward to seeing these too.
Old 03-13-2012, 11:47 PM
HioSSilver's Avatar
me three. Gains?
Old 03-13-2012, 11:54 PM
bczee's Avatar
I've seen a few on this forum.. but Can't recall which project they were.. hopefully they will chim in with some pictures..
BC
Old 03-14-2012, 12:02 AM
Wildkard's Avatar
I need to get some pictures of mine online, hopefully in the next week or two, but it turned out really well I think. I basically ground EVERYTHING off the top, and then layed a couple of layers of fiberglass on top to cover up all the holes. Each of those protrusions on the older truck intake will be a 1" x 1.5" oval hole if you grind them out smooth. Probably 5 hours total of work, not counting all the curing time for the fiberglass and paint, but worth every minute for how much better it looks.
Old 03-14-2012, 12:03 AM
trav-tech's Avatar
Originally Posted by HioSSilver
me three. Gains?
I believe the gains are in the looks of the manifold as they are talking about smoothing the outside.
Old 03-14-2012, 12:18 AM
the_merv's Avatar
Like this...
Here is a thread from the S10 Site I'm on..
http://www.s10forum.com/forum/f213/t...pretty-460483/
Old 03-14-2012, 01:41 AM
91sonomast's Avatar
They look really good once cleaned up, plan on doing it to mine
Old 03-14-2012, 04:00 AM
kwnova9's Avatar
on my nova Name:  0812111223a.jpg
Old 03-14-2012, 04:06 AM
massen1981's Avatar
got one on my elcamino. it is in my buildtread.
cant post pic now am on mobile phone
Old 03-14-2012, 04:46 AM
99VetteFRC's Avatar
Originally Posted by the_merv
Like this...
Yhis is what I'm after. How about the purge solenoid hole? What are guys using to block the hole?
Old 03-14-2012, 07:09 AM
72_Cutlass_LS_Swap's Avatar
1st time I've ever seen this done on a truck intake, looks alot better in my opinion
Old 03-14-2012, 07:41 AM
garys 68's Avatar
not mine, but looks good
and another
Old 03-14-2012, 10:42 AM
the_merv's Avatar
^^First time I've seen that one..that looks bad ***.
Old 03-14-2012, 11:48 AM
Wow that silver one is nice!
Old 03-14-2012, 12:13 PM
Capown's Avatar
looks like they cut out and patched all the bungs or what ever they are and smoothed it. That looks awesome, I'm gonna have to look into a plastic welder.
Old 03-14-2012, 10:32 PM
LS1 pwrd NOVA's Avatar
Sweet intake work, might have to do one of the extra ones i have since they barely sell or you cant give them away
Old 03-15-2012, 02:15 AM
Rat Chevelle's Avatar
I also painted mine.
The sanding is a bit boring since the plastic tends to clog your sandpaper.
Bwefore sanding though I used a "hobby saw" (for the lack of a better name) and then used the carbide bits ion my high speed grinder to create a sort of smooth finish.
Then the final sanding... I did not take it to where I wanted since I got tired of it, then some adhesion promoter, filler primer, metallic silver, and a coat of clear.
It really attracts attention on my C-10.
Attached Thumbnails Smoothed Truck Intakes-img_0478s.jpg   Smoothed Truck Intakes-img_0479s.jpg
Old 03-18-2012, 11:12 AM
99VetteFRC's Avatar
I started smoothing my extra intake. It should turn out nice.
Attached Thumbnails Smoothed Truck Intakes-dscn1215.jpg   Smoothed Truck Intakes-dscn1216.jpg   Smoothed Truck Intakes-dscn1217.jpg
Old 03-18-2012, 01:28 PM
nos487's Avatar
Looks good keep the pics coming.
Quick Reply: Smoothed Truck Intakes
