Fuel pump on constantly with ignition???
I installed a whole new fuel system this winter, and went to test the pump and when i turned the ignition on the pump just stayed on, and wouldnt go off. It used to prime for about 2 seconds then turn off. The pump is a Magnafuel 750 so i can easily hear it . I check all the wires and nothing has changed since last year. What would make the pcm want to prime then stay on, i thought it went off the crank sensor???
Did you change relays? Change any wiring at all? If not, then I'd suspect it's a relay issue, as they trigger the pumps on/ off. I've never seen a relay go out due to non-use, but I guess it's possible. Try lightly tapping on them to see if the pump will turn off.
Double checked all the grounds firewall forward to make sure none were loose or off. I only have about 4 grounding spots as i redid my whole damned harness. One of them was loose, i grounded it and it worked. Didnt do much testing just making sure nothing was my fault first. This time happened to be human error.
