Fuel pump on constantly with ignition???
Old Mar 18, 2012 | 03:20 AM
BlackWS666's Avatar
Default Fuel pump on constantly with ignition???
I installed a whole new fuel system this winter, and went to test the pump and when i turned the ignition on the pump just stayed on, and wouldnt go off. It used to prime for about 2 seconds then turn off. The pump is a Magnafuel 750 so i can easily hear it . I check all the wires and nothing has changed since last year. What would make the pcm want to prime then stay on, i thought it went off the crank sensor???
Old Mar 18, 2012 | 05:24 AM
98Camarod's Avatar
Did you come off of the factory trigger wire?
Old Mar 18, 2012 | 12:40 PM
BlackWS666's Avatar
Yes i used the factory wire to trigger the 2 magnafuel relays. Worked great the last 3 years.
Old Mar 18, 2012 | 01:49 PM
Did you change relays? Change any wiring at all? If not, then I'd suspect it's a relay issue, as they trigger the pumps on/ off. I've never seen a relay go out due to non-use, but I guess it's possible. Try lightly tapping on them to see if the pump will turn off.
Old Mar 18, 2012 | 08:30 PM
BlackWS666's Avatar
I swapped it out with another and no difference. Is it possible the crank sensor is stuck?
Old Mar 20, 2012 | 03:30 PM
joecar's Avatar
Either:
- fuel pump motor circuit is shorted to power;
- fuel pump relay control circuit is shorted to ground;
- PCM is faulty.
Old Mar 21, 2012 | 12:34 AM
BlackWS666's Avatar
Originally Posted by joecar
Either:
- PCM is faulty.
It was #2. found the problem today. Thanks for all the help guys.
Old Mar 21, 2012 | 04:42 AM
Need_a_Camaro's Avatar
Mines doing the same thing, how did you narrow down your issue?
Old Mar 21, 2012 | 08:07 AM
BlackWS666's Avatar
Double checked all the grounds firewall forward to make sure none were loose or off. I only have about 4 grounding spots as i redid my whole damned harness. One of them was loose, i grounded it and it worked. Didnt do much testing just making sure nothing was my fault first. This time happened to be human error.
Old Mar 21, 2012 | 08:09 AM
Ah, well some jack asses I had doing some work to my car decided to hack the harness up. Now, the pump stays on. Guess I need to break out the schematics again. Love the build by the way.
