View Poll Results: Lean cruise.. possible?
Yes
5
100.00%
No
0
0%
Voters: 5. You may not vote on this poll
might be ressurecting an old idea but... lean cruise how to do it??
Old 03-19-2012, 09:44 PM
h_friesen's Avatar
Default might be ressurecting an old idea but... lean cruise how to do it??
Well after several hours of endless searching on several sites, including efi live, hp tuners, ls1tech of course. I have not been able to find anything conclusive on this matter. Seen people post that you have to combine the v body platform code from a holden and a stock f body platform pcm in order to get lean cruise to work. Seen Frost tuning claim its possible to unlock such cals in tunercat obdII and then be able to tune the tables in hpt. Seems as this is a hush hush topic without anything conclusive, to the best of my knowledge of course. Would anyone care to shed some light on the matter? Via this thread or via pm im curious how to get this to work, i know its possible with the proper software and such. Appreciate the help in advance
Old 03-20-2012, 11:46 AM
gi8e7oi825's Avatar
**** I'd like to get this working too, with the price of gas and all
Old 03-20-2012, 06:00 PM
sreve's Avatar
It can be made to work with TC2 or EFI
This is only for light throttle steady state cruise 50mph or faster.
I'm running @ 16.5 : 1 afr on LC or about 9 or 10%.
Old 03-20-2012, 07:02 PM
CalEditor@PCMCalibrators's Avatar
if you have E10 in your tank then you are about 15.3 now
If you want to set it for 16.5 and run E10% you would be over 17 to 1. I just don't see how the engine is able to get a good MBT. To me it seems about the same as adding EGR to an engine.
Old 03-20-2012, 07:56 PM
89 formula350's Avatar
check out the old OBDI stuff its been unlocked in many of the gm cals. it works but keep in mind unless you do alot of hwy driving your wont notice the improvement. I think the ave was around 5% with 90% hwy driving
If you know hex you can enable it. last time I checked it was pretty much spelled out in a few forms
Old 03-21-2012, 08:36 AM
1CAMWNDR's Avatar
Can't you go Open Loop Speed Density and just tune the cruise area of the table to whatever AFR you want?
Old 03-21-2012, 01:51 PM
minytrker's Avatar
You can easily do lean cruise with a f body with EFI Live.
Old 03-21-2012, 08:45 PM
It has a platform check in the OS so if its an f-body it disables the function. holden platforms will work but from what ive heard (yes heard).. its not as simple as going into efilive and flipping the platform select as this does not truly allow the function... there is something underlying that does not change in efilive platform selection.
the way to do it is go into the hex of the OS itself and allowing the code to allow lean cruise to apply
Old 03-21-2012, 11:10 PM
h_friesen's Avatar
That's is what I have gathered as well. It has got to be a bit more challenging than buying TC and enablijg the cals to enable it to run. I have access to hpt, that's what my tuner uses, can anyone tell me a little more on the TC method?
Old 03-21-2012, 11:14 PM
h_friesen's Avatar
The efilive side to this is running some .cax files (which I have) to turn this on. Then also really writing the actual hex code in the OS, which I have no to clue how to do. If anyone would care to share a hpt LC tune with me that I can adapt to my setup. Please pm me.
Old 03-22-2012, 11:05 AM
SSpdDmon's Avatar
Aside from running open loop, the easiest solution is to use a more cautious right foot and slow down 5mph. I'd be willing to bet driving more conservatively and doing 5 over instead of 10 over can easily net you 1~2 mpg on average. For a driver who does 12k miles per year and is concerned about money, that 1~2mpg equates to ~$13 per month. So, whether you tune differently or drive differently, it's not a major difference when all is said and done. And if $13 per month is a big deal, then I'll use the Ferrari logic....don't drive the car if you can't afford the maintenance.
Lean cruise really isn't worth the time/effort IMO.
Old 03-22-2012, 12:07 PM
bmax's Avatar
I had it enabled for a while. On road trips thru the mountains I didn't see much improvement in MPG.
I went back to open loop, commanding what I want in the cruise areas.
As already said, the best mileage improvement is less right foot.
Brad
Old 03-22-2012, 12:18 PM
gi8e7oi825's Avatar
After some adjustments, I'm stuck at 28.5ish mpg and would love to see over 30 mpg in my f-body. My other cars can do well over 35, but they don't have the power there when it's needed. I'm going to see what I can do with this... but I'll try open loop first, I suppose.
Old 03-22-2012, 05:10 PM
joecar's Avatar
In EFILive you copy the .cax file matching your OS id to a specific folder, then you enable LC, then you populate the LC table(s), then you full flash.
The mpg improvement is not spectacular, like was said above, you can achieve better with careful use of your accelerator foot...
you got a muscle car (modded with cam/stall) and you want to improve your mpg (rather than your hp)...!?!?
Old 03-23-2012, 10:25 AM
minytrker's Avatar
Read the responses above this post. I just didnt feel like going into detail on how you do with EFI Live, but its easily done.
Old 05-26-2012, 05:25 AM
The Dragon's Avatar
Thumbs up
Originally Posted by sspddmon
aside from running open loop, the easiest solution is to use a more cautious right foot and slow down 5mph. I'd be willing to bet driving more conservatively and doing 5 over instead of 10 over can easily net you 1~2 mpg on average. For a driver who does 12k miles per year and is concerned about money, that 1~2mpg equates to ~$13 per month. So, whether you tune differently or drive differently, it's not a major difference when all is said and done. And if $13 per month is a big deal, then i'll use the ferrari logic....don't drive the car if you can't afford the maintenance.
Lean cruise really isn't worth the time/effort imo.
ditto all of that.
Old 05-26-2012, 11:10 PM
Pontiacerator
RevGTO's Avatar
Yep it is easy to do. I ran it for a while and monitored it with my wideband. I found there was quite a bit of variation in the readings, and some of the leaner results made me nervous. Went back to conventional and haven't looked back.
Old 05-27-2012, 12:00 AM
01ssreda4's Avatar
Any idea on what is the safest high AFR that is acceptable during cruise situations. Curious...
Old 05-28-2012, 11:22 PM
SSpdDmon's Avatar
I personally wouldn't push it much higher than 15.5~16:1.
Old 05-30-2012, 12:50 PM
69 Ghost's Avatar
For TC it is a patch. You check a box to enable it. Of course you have to then edit some tables. If you check on the Monodax site the settings for lean cruise that were used down under are posted there.
Quick Reply: might be ressurecting an old idea but... lean cruise how to do it??
