first time at gateway
Old 03-20-2012, 11:53 PM
1999transamls1's Avatar
Default first time at gateway
i did 5 passes, first 4 were between 13.70-13.79 and the last one was 13.83.
best 60 foot was 2.19, worst was 2.33
traps were all 104, not sure whats going on just couldnt launch worth a ****
it was also my first time there, so i dont think i did to bad with only longtubes ory tune and lid mph wise.
i also have 2.73 rear gears
da was 1843 at 9pm which was my last and worse pass, 13.830 2.330 60 foot and 104.2 mph
Old 03-21-2012, 12:00 AM
Zmg00camaross's Avatar
Not terrible man. Just need to get that 60ft down and times will fall.
Old 03-21-2012, 12:08 AM
yea i have no idea what was up with that, no matter what i did i couldnt get it down at all. im gonna try with my 315/35/17 nt05r's. i had nt555s 275/40/17s on today.
Old 03-21-2012, 01:57 AM
Firebird Phoenix's Avatar
Awesome man. I'm so excited that Gateway is back open. I plan on hopefully going next Tuesday, weather permitting and all to run my T/A for the first time.
Old 03-21-2012, 06:57 AM
the track seemed a little slippery still, nobody i know was getting really good 60 foots.
im planning on getting a 3.42 rear end out of a m6 car to replace my crappy 2.73's, and ill bring some drag radials next time, what else should i do to get that 60 foot down?
Old 03-21-2012, 07:13 AM
SuperSlow02's Avatar
Suspension or a converter.
Old 03-21-2012, 07:15 AM
JUSTINSWS6's Avatar
What color was your car? I saw a just catback aito ls1 run 13.3 consistent last night.
Old 03-21-2012, 08:18 AM
blk/slvr02ss's Avatar
Low Air pressure like 25PSI Street tires 18 PSI drag radials,Suspension and figure out were your car likes to b launched like off idle or bring the RPM up little @ a time until you find the sweet spot w/ a better 60 ft and Yes get a 3:42 Rear they r perfect for auto's !!!!
Old 03-21-2012, 08:24 AM
Nbm there was a couple cara there running just a tenth or 2 faster but with 2.0 60 foots
Old 03-21-2012, 08:27 AM
Also I'm doing a yank 4000 converter later this year, just wanna get some suspension stuff and sticky tires first. I might go back next tuesday with drag radials and see if that helps over my 275 street tires
Old 03-21-2012, 09:46 AM
moge11's Avatar
your car is missing AT LEAST 5mph!!! MINIMUM!!! runs like a STOCK car.. and not just stock, but a SLOW stock car... not hating on you, but you gotta figure out what is wrong!! SERIOUSLY dude, thats a full second off pace..... something aint right.. you gotta any issues goin on that youre not tellin us????
Old 03-21-2012, 10:25 AM
Not that I know of, only thing I can think of is the 2.73s are holding me back, but still I thought it would be faster. It was also my first time at a drag strip ever. I was thinking it would be high 12's which looks right with a 1.8 60 foot
Old 03-21-2012, 10:27 AM
Also I think muffler is a restriction, it's a dynamax turbo 1 in 2 out. I'm gonna get a cut out and see if that helps. I had lm1 on it but it was welded bad so I thought this was a good replacement, but right after it felt slower
EDIT: talked to my tuner about knock sensor code i had/have, he said its pulling 8 degrees of timing, hes gonna go out with me one day and log the run and we'll see
Old 03-21-2012, 02:00 PM
moge11's Avatar
my muffler is stock and isnt a restriction
Old 03-21-2012, 02:26 PM
i know that after talking to my tuner, its my knock sensors pulling timing
Old 03-21-2012, 02:46 PM
MFJ
MFJ's Avatar
My muffler is stock too. I don't think it's that restrictive either. Knock sensors could be it though. Your car should be way faster than your times. Especially an A4 car.
Old 03-21-2012, 08:43 PM
1Bad97WS-6's Avatar
My PB with 273s and stock stall with bad knock sensors. with LT's/ORY/Free Mods/Lid/K&N/NGK TR55s/8.5mm MSD/Smooth bellows.is an 2.03 60ft 12.97@107.88. The DA was 890-960..
Oh ya what did the 1/8 look like and how much mph did you gain from the 1/8 to the 1/4. My car does its best from Idle to wot with stock stall/gear
Old 03-21-2012, 09:01 PM
I was 83.5 mph 1/8 mile, but after looking at the videos, I was spinning pretty bad
Old 03-21-2012, 09:50 PM
Is there a new website for gateway? Is there a scheldule?
Old 03-21-2012, 09:59 PM
JUSTINSWS6's Avatar
Yes gatewaymps.com everything is on there.
Quick Reply: first time at gateway
