estimated mpg 6.0 chevelle
Old 03-24-2012, 06:08 PM
Smitty454's Avatar
Default estimated mpg 6.0 chevelle
So I've decided to go with a 6.0 instead of a 5.3 because I don't have the skill to fab up a turbo and I would like to keep the swap cost to a minimum.
I currently have a 461 with a th350 and 4.11 gears. As you can imagine, its not very street friendly and the gas mileage is god awful at 8mpg or less.
My plans are to sell or part out the BBC, sell the tranny, and use the money to put together a 6.0, higher gears in the 3.42 range and an overdrive auto or manual tranny.
What kind of mpg could I expect with the above combo?
Old 03-24-2012, 06:11 PM
Goldhawg's Avatar
Based on what others have seen, I'm guessing 23-24 on Highway if you don't have your foot in it. Perhaps a bit better.
Old 03-24-2012, 06:53 PM
68BBChevelle's Avatar
I say keep the 4.11s and get a t56. That will be a fun ride. Im hoping to be up and running in about a few weeks, Im doing a 6.0 swap with th400 with 3.55s im waiting to see what that combo will do.
Old 03-24-2012, 09:33 PM
Smitty454's Avatar
I would like to do that ideally. But that's all depending on the gas mileage I get.
garys 68's Avatar
Keep the 4.11s, get the T56 with 0.5 OD.
My 5.3 72 442 with a Muncie and 2.73 rear gets 22-23mpg. A 6.0 with 4.11s and 0.5 OD should be similar.
Old 03-24-2012, 11:24 PM
Smitty454's Avatar
I dont know about that Gary lol.
Old 03-24-2012, 11:29 PM
bczee's Avatar
I have an Stock LS1 (LS6 intake and Long Tube Headers), a Viper T56 (0.50 6th gear as compared to a GM T56) and 4.10 gears.. I turn 1750rpm at 65mph. But usually cruise between 70-75mph.. I get 26mpg on the Highway.
BC
Old 03-25-2012, 07:27 AM
garys 68's Avatar
The 22mpg is a combo of city and hiway as my DD.
The 6.0 LQ9, Richmond 0.76 OD, 3.08 rear (2.34 overall) runs at 2000 rpm on the highway. Best of 26mpg. You'll be turning a few less rpm with the T56/4.11, that helps, but the chevelle will be a couple hundred pounds more and less aerodynamic. So I'm thinking low to mid 20s is pretty realistic if your foot isn't too heavy.
I dont think a 3.42 rear is practical in a heavy vehicle using a 0.5 OD, so you gotta ask yourself if the cost of a 3.72 swap is worth a couple percent increase in milage. My experience is in my old camaro is that even the 30% rpm change with OD would only increase milage about 10% on hiway. A 10% change in the rear would be considerably less and probably negligable in city driving.
Old 03-25-2012, 09:47 AM
Pop N Wood's Avatar
BC
Man, that sounds like the ideal set up.
Old 03-25-2012, 11:24 AM
Smitty454's Avatar
Wow I guess I am wrong. I think im just cynical towards my 4.11s haha. Im going to look into what it takes to swap in a T56 as I have an automatic right now. Thanks for the ideas!
Old 03-25-2012, 01:54 PM
ls68firebird's Avatar
maybe concentrate on the rest of the swap and try the 4.11's first. at least you can change them later without disturbing anything else. But let us know how the mileage works out both ways.
Old 03-25-2012, 03:00 PM
Goldhawg's Avatar
I tend to agree. I have 3.73 gears w/15 in 235/60/15 442 wheel/tires on my cutlass. I could only use the 6th gear for highway cruising w/my LT1/t56 combo. When I had my T56 built I had TDP put in the higher number 5th/6th gear combo (forget but 6th gear closer to .6). Hoping to enjoy 6th gear more w/my LSx setup.
Quick Reply: estimated mpg 6.0 chevelle
