1970 Nova 5.3/s475
Old 03-28-2012, 12:43 PM
2baditsnotachev's Avatar
Default 1970 Nova 5.3/s475
Well I guess ill start a build thread here too why not. The car is a 1970 Nova and im putting a junkyard lm7 in it with a bw s475 and will be run with an ms1.
Old 03-28-2012, 12:46 PM
Old 03-28-2012, 09:09 PM
ls68firebird's Avatar
cool! i would love to put a turbo on my daughter's car. keep the pics coming.
Old 03-28-2012, 09:28 PM
alexcoreas's Avatar
Subscribe.
How much did you pay for the BW S475?
Old 03-28-2012, 11:17 PM
Originally Posted by alexcoreas
Subscribe.
$745 from forcedinductions its the 83mm/1.10t6
Old 04-01-2012, 09:12 PM
Old 04-02-2012, 12:55 PM
LanceL's Avatar
WOW great start!! I am just about to do this. What motor mount plates did you use? Also it looks like you are trying to make the exhaust manifolds work facing down instead of up. I thought on the Nova/Camaro it wouldn't work because of hitting the control arm? It looked like in one pic you cut off the flange? What did you do? Looks good
Old 04-02-2012, 05:30 PM
I am using neutral position trans dapt plates. The manifolds are an ls4 on the passenger side with a truck manifold on the drivers side. The truck manifold flange needs to be angle milled at 6° to tuck it in enough to clear the rear steering box. Both manifolds will be v banded also for more room.
Old 04-02-2012, 05:49 PM
LanceL's Avatar
Any more pics of the manifolds? Do you like the trans dapt plates?
Old 04-02-2012, 09:46 PM
Old 04-02-2012, 09:48 PM
The transdapt plates bolt pattern sucked I had to elongate one of the bottom holes on each side for them to bolt to the block nicely.
Old 04-03-2012, 02:00 AM
Old 04-03-2012, 02:23 AM
ten5nova's Avatar
Thanks for sharing, I'm getting some good ideas for my own turbo build. Nice work so far!!
Old 04-06-2012, 01:34 AM
Old 04-15-2012, 02:28 PM
Got my gates on
Old 04-15-2012, 04:47 PM
Received 3,369 Likes on 2,085 Posts
Dude, that is a nice job! Love the color of your car. Nice work.
Old 04-15-2012, 06:54 PM
98BuickGS's Avatar
Nice car and combo. What fuel will you be using. Why no intercooler? Where in minnesota are you?
Old 04-15-2012, 07:12 PM
72montecarlo's Avatar
Badass
Old 04-15-2012, 07:32 PM
Thanks guys, I plan to run e85 and low boost this season then step it up next year with an a2w under the dash. All I plan to do is flip the tb elbow and run the charge pipe around it and into the firewall. Im in Coon rapids Mn.
Old 04-16-2012, 01:17 PM
chevellepowered's Avatar
looks badd ***..clean setup.. on hot side so far..
Quick Reply: 1970 Nova 5.3/s475
