C5 vs C6 harness setup?
Hey,
Trying to decide between the C5 and C6 harness for my BMW Z4 swap. I want to run electronic throttle (thus why I'm using Vette vs. F-body harness) but have no idea which would be the better setup.
Is there any advantage to one over the other?
I'm looking at using an LS2 intake for the 90mm TB, but will stay with the older LS1 injectors (will rewire the injector harness) availability and options.
I'm not concerned with the 24 vs 58 tooth crank wheel as I can swap wheels as need be.
Besides the harness and ECU, does the C6 have a TAC module like the C5? I looked on eBay and the C5 TAC modules are near $500!
Thanks,
Chris
Thanks,
Chris
LS1Tech Sponsor
The LS2 does not have a tac module. The vette LS2 is 58x and all throttle functions are taken care of by the ECM. FYI, even the 24x LS2 engines did not use a TAC Module. You will need spacers for the fuel rails if you are going to try and run an LS1 Injector with an LS2 intake and fuel rails. Why not just run an an LS2 intake with LS2 or LS3 injectors. They willl flow more than LS1 (unless we are talking aftermarket injectors here).
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
