Alternator battery line will not come off.
How do I get it the line off. The freaking nut keeps turning the line and the second nut behind the line. I can't get anything small enough on the second nut to hold it. What are you guys using or are you cutting the line and recrimping it?
wrencher
The battery is diconnected right?
I use a thin 10mm wrench to get it off.
Maybe a sears sells them individually??
I rather keep the stock alternator eyelet connector, a cheap wiring terminal fix there is not the best idea.
I used a 10mm but the second bolt keeps spinning. I think I found my problem with my alternator. In this pic you will see a red wire entering some black opening being held in by some red cap or something of that nature. I noticed my red wire was just hanging around and that red cap is totally missing.
Look at the two nuts. This is my problem. I turn one and the other turns also. I tried to get a needle nose plyer behind there, but can't get a good grip.
wrencher
Hey!! that's a LT1!!
No but seriously, thats what I mean I wrench on outer nut & there are special "thin" wrenches that can grab that inner one.
That red wire is for the regulator & that is it's connector, not sure if I follow what your saying is the problem with it?
Thanks man. Yeah I know that is an LT, but that connection is the same. My red wire is cut and the plug itself is missing. Thanks for the info. I'm going to get a small 10mm today and get it up in there. Going to remove the alternator regardless so I can find the freaking power steering leak.
I got the alternator off. I need the part number for the field wire plug. I went to a dealer and I had them look up alternator connector and they showed me a 4 wire connector. Gonna try another dealer and use "field wire" as the name. I tried gmparts direct, but couldn't find it.
