which cometic head gasket and why?
Old 04-03-2012, 09:09 PM
poltergeist 02's Avatar
Question which cometic head gasket and why?
I'm getting ready to order head gaskets and I'm trying to figure out which cometics to use with my set up. There seem to be many options cometic offers for an LS1. Which gasket would yield the best performance gains?
This is what i have:
stock bottom ls1
comp 228/230 .571/.573 112lsa (intake 71* abdc)
ported unmilled 799 heads with stock valves
cometic gaskets:
part# / compressed thickness
C5475-040 (.040")
C5475-036 (.036")
C5475-030 (.030")
C5475-027 (.027")
Old 04-04-2012, 06:11 PM
any advise?
Old 04-04-2012, 06:24 PM
baxsom's Avatar
the only thing i know about the cometics is that they are not as forgiving as the oem MLS gaskets about the sealing surface. from what i have been told both the block and heads have to be perfect.
Old 04-04-2012, 08:33 PM
batboy's Avatar
I would not go thinner than .040" due to reduced quench clearances and due to the thinner you go the harder they are to seal. Personally, I like the GM MLS gaskets.
Old 04-05-2012, 01:03 AM
SmithS87's Avatar
I had the same question. Actually, I registered specifically to say to ask this question..
So, any advise will be so much appreciated
Old 04-05-2012, 01:21 AM
gectek's Avatar
.040 or .045 for me. Also depends on how much the piston sticks out of the hole.
I would use a 3.910 or so head gasket to keep the quench higher also.
Old 04-05-2012, 05:05 AM
ausls1's Avatar
With stock pistons id use the .040" gaskets, i'm using a .027" cometics gaskets but iv also got -8cc dish pistons, if had a smaller dish piston would've used a .040" myself.
Old 04-05-2012, 05:33 AM
redtail2426's Avatar
yeah i used the .045,but if i could have done it again i would have went with the .040.. I also have the same cam as you OP
Old 04-05-2012, 06:07 AM
mark21742's Avatar
I'd also use the .040". On average your piston sits around .005" up out of the hole so that would give you a .035 quench..035-.030 is optimum, when you get tighter there are gains, but as the metal stretches and expands it leaves less room for error.
Old 04-06-2012, 02:32 PM
are the cometics as good as the gm mls gaskets?
Old 04-06-2012, 03:15 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
We keep them in stock. Shoot me a PM or give us a call and we will get you fixed up!
Old 04-06-2012, 03:41 PM
pairof69s's Avatar
i'm gonna try the FP permatourque gasket, it's just a stock LQ9 though..
Quick Reply: which cometic head gasket and why?
