LS4 Performance - Harmonic Balancer............
View Full Version : Harmonic Balancer............
Sadden
04-13-2012, 11:34 PM
Mines on its way out , looking into changing it.
Dealer quoted me 360.$ :l
I can change it myself but i need to know if there is any aftermarket one available , i saw some discussion about it from threads past but it doesnt look like anything ever came to fruition.
Anyone?
neilownz
04-14-2012, 08:09 AM
If I remember right it was tough finding the part.
smokin06impala ss
04-14-2012, 04:17 PM
What are the signs that the harmonic balancer is on its way out ? Are they visual or you start feeling some sort of vibration ? Just curious
Sadden
04-14-2012, 05:17 PM
Mine started with a noise, caused a bit of belt slip , now i can physically see it wobbling........
neilownz
04-14-2012, 06:16 PM
Try just replacing the bolt.
Sadden
04-14-2012, 08:41 PM
Are they known for breaking?
Never heard of that before , wouldnt that cause the whole bit to come off?
neilownz
04-14-2012, 10:43 PM
I think I remember someone's loosening up and the bolt can only be torqued once. If it wobbles long enough the hole might get bigger.
Andrew91PGT
04-15-2012, 07:22 PM
No aftermarket support for this that I've heard. Order a new bolt and Balancer from WWW.gmpartsdirect.com
gxp-miller-gxp
04-16-2012, 12:03 AM
the dealer replaced the bushing on mine and its fine now
Andrew91PGT
04-16-2012, 12:18 AM
I've never seen a Balancer have a serviceable "bushing"? The Balancer itself has rubber separating the inner and outer of the pulley itself to dampen vibrations. Usually this is what deteriorates creating problems.
2002kirk
04-19-2012, 11:21 PM
Anyone?
i have a 2006 impala ss and mine is wobbling bad now and the dealer quoted me just over 1k so 360 sounds amazing because i dont have the time to do this and i need my car...
Sadden
04-20-2012, 12:31 AM
Thats 360 just for the part , i sourced one for under 300 elsewhere and will install myself.
bahdeets
05-02-2012, 09:29 PM
I am not sure who is quoting $360 for a balancer, but I just bought 2 from my local chevy dealer for my LS4 and they only list for $209.00 and with any kind of discount they can be had for around $150.00/$175.00 or so @ the dealer.
DavidGXP
05-03-2012, 01:28 AM
Go thru gmpartsgiant.com to get the balancer bolt and balancer. They sell parts at wholesale cost, so you save big bucks!
You will also need to rent a puller and installer.
In order to remove the balancer, you will need to drop the cradle and use a impact gun to remove the bolt. If you do not have access to one, then you will need to use a flex plate holding tool (GM specific) with a large/long breaker bar.
The balancer bolt needs to be torqued and the streched, so you will also need a torque wrench with a 1/2" drive angle gauge.
This might seem like lots of work, but I can do the whole job in about an hr. Do take your time though, and good luck.
NVR_ENUF
05-03-2012, 08:49 AM
On my old GTP, I've used a pair of vice grips on the flywheel to keep the engine from rotating. There's a small black plastic cover on the bottom where the engine/trans connect. Take out the one or two 10mm bolts and remove the cover to expose a small portion of your flywheel. You won't ruin it with a set of grips. Its hardened steel, and I doubt you can squeeze hard enough to damage it.
As far as the pulley puller, you should be able to rent one from Advance Auto or Auto Zone.
Sadden
05-12-2012, 01:00 AM
I live in Canada , our pricing is alot different , especially on specialty stuff like this..
And i get 10% above their cost...
I used a prybar on the teeth to hold it in place.
And the bolt is called Torque to yield...
They are supposed to be single use , but a lil bit of lock tite and its good to go...
Dropped the cradle , replaced the HB , and bolted it back up , ill finish the rest off after work tommorow night.
DavidGXP
05-12-2012, 02:26 AM
My car was built in Canada.
Sadden
05-12-2012, 10:22 PM
Just checked mine so was mine.
Shes all back together and running strong.
DavidGXP
05-12-2012, 10:35 PM
I wonder if all gxp's were built in Canada?
Sadden
05-13-2012, 12:40 AM
If your vin starts with a 2 it was built in Canada , a 1 or a 3 and it was built in the USA.
AZsilverSS
01-24-2013, 09:04 PM
Add my 2006 Impala SS to the list.
Engine was screeching when started during very cold (<10 degrees in AZ) - so opened the hood to see what was up - and although not the cause - saw that the balancer was wobbling.
Replaced today by local Chevy dealer - $186 for balancer, $28 for seal and $616 for labor. Took a day to get the balancer from CA.
91parkave
01-24-2013, 09:25 PM
Did you pay out of pocket? 616 for labor seems very high
DavidGXP
01-24-2013, 11:04 PM
All balancers wobble. I would have had them replace then tensoner too.
