Fueling & Injection - Edelbrock Fuel Rails
FASTLS1WS6
04-26-2012, 03:26 AM
I have Edelbrock fuel rails that come with the LS1 vic jr intake manifold. I am using AN fuel fittings. There is fuel leaking on the ends of the fuel rails. I was wondering if this is somthing that happens often. I am pretty sure that I have the fittings tight enough and I am hoping the fuel rail is not cracked. This is leaking on the passenger rail on the front and the driver rail on the back.
MikeFSKSpeed
04-26-2012, 07:31 AM
What fittings are you using? I believe those take metric fittings with a crush washer
Gray86hatch
04-26-2012, 05:56 PM
3/8 npt
FASTLS1WS6
04-26-2012, 11:16 PM
I am using the 3/8 npt
98Camarod
04-27-2012, 04:39 AM
Dumb question, did you put thread tape on it? If so, then I'd look and see if there is a crack in it.
FASTLS1WS6
04-28-2012, 09:44 AM
I did not use thread tape but I did use a sealer in the threads that fuel would not eat through.
98Camarod
04-28-2012, 10:38 AM
I'd recommend swapping to the thread tape.
FASTLS1WS6
04-29-2012, 09:19 AM
I will give that a try. I looked at it closer and the fuel rail is not cracked. I am afraid if i tighten the fittings more that i might crack the fuel rail.
97badass
04-29-2012, 09:35 AM
I have never had the dope not leak. I always use thread tape even when not recommended. Just don't over tighten it (reason its not recommended) because you can tighten it more with the slick surface of the teflon.
Gray86hatch
04-29-2012, 06:54 PM
I run a tap thru them before install just to make sure they are good. Tape never a leak
Tim
97badass
04-29-2012, 11:13 PM
Gray did i ever leave you feedback for that head i bought from you? It looks a little different than when you sent it to me... .030 milled off and bead blasted and bowls polished.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
