Generation III External Engine - 102mm throttle body fit a pro flo?
bad6as
04-26-2012, 08:45 AM
im wondering if any one knows if a 102mm throttle body will fit a edelbrock pro flo intake manifold
dodson55
04-26-2012, 08:52 AM
it should bolt up not sure how big the opening is on a pro flow you may have to port it to get to a 102 opening
bad6as
04-26-2012, 09:08 AM
the proflo im looking in to is thels2 style so it has the edelbrock 4 bolt pattern and the standard ls2 4 bolt pattern and uses an oring seal. the 102mm tb has the ls2 bolt pattern so if some porting is needed im not against it. but i need to know how much may need to be ported or if its even possible to open it up that much.
any one have a mesurement of the pro flo opening?
Cosmos
04-27-2012, 04:43 PM
Talked to edelbrock and its a 90.
SweetS10V8
04-27-2012, 09:08 PM
Ive ran it on the dyno...... 90mm......
bad6as
04-27-2012, 10:30 PM
So any thing then a 90mm the opening on the proflo will need to be opened up?
Would it be worth it to open it up some to fit a 92, 95, or 102mm ? Looking for 1k wheel threw a th400
Cosmos
04-29-2012, 11:55 AM
If your going boost I would just keep it at 90mm.
My6speedZ
11-07-2012, 12:10 AM
I know this thread is old but I figured I would post this in case someone ever searched this topic:
richard@proheads.com
9:51 AM (15 hours ago)
to me
We've never been asked to port them to that size but I don't see any issue doing that. I believe most large throttle bodies stay within the factory O-ring seal. The flange has plenty of metal to grind if needed.
Richard Reyman
West Coast Cylinder Heads
