LS4 Performance - Anyone's car die when hitting a big bump?
BlackImpSS
04-28-2012, 03:37 PM
It's happened twice now and I have no idea what could be cauing I figured it was just a loose battery cable, but it's def tight.
Thanks,
Jake
Aaron_Provost
04-28-2012, 04:02 PM
Do you have a CAI? If so, check to make sure the case is not touching your starter.
dtsti
04-28-2012, 04:07 PM
Might sound dumb but is your knee hiting the key when you hit the bumps?
BlackImpSS
04-28-2012, 04:35 PM
Nope still have the stock intake for now, and I don't think my knee is hitting the key...wouldn't it have to turn the key to shut the vehicle off?
Vectus
04-28-2012, 05:25 PM
Id check the air box like Provost said, even if its the stock one. I had that happen before.
critical.in.ga
04-28-2012, 06:05 PM
The stock air box is plastic tho
My car does it too man and i cant figure it out.. kinda hard to troubleshoot sumthin that only happens when u hit a bump ya kno. Check all ur engine/chassis grounds too... pcm connections, actually jus check all the wiring u can for anything loose or exposed wire.
UseAsDirected
04-29-2012, 10:23 AM
My 3500 Impala used to die randomly... it was loose connection in the fuse box. Not sure exactly what connection it was because it was under warranty and the dealer dealt with it but it had them boggled for months.
straitchev
04-29-2012, 12:00 PM
my olds intrique with a 3800 did this. Never ended up figuring out the problem and was the reason I ended up selling it
ryanisl33t
04-29-2012, 03:32 PM
Sounds like a loose ground...check/clean those.
BlackImpSS
04-29-2012, 04:14 PM
I didn't expect this to be a common problem. I guess I will take a look at the grounds. It has only done it twice, but I would hate for it to happen to the GF was driving with my daughter. I told her what to do, but who knows if she will remember or just freak out. First time it happened when I was doing 75 down the interstate. If I cant trace down the problem I guess the dealer will have fun, since its still under warranty.
