Forged 6.0 long block LS
Category: Accessories
Price: $3000
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): MN
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9
LS Engine?: Fits LS Engine
Callies Comstar 6.125" H-Bean rods rated to 900HP
GM 6L crank .010
Clevite bearings
In Motion timing set
Comp 220/224 .581/.581 114 LSA
PAC beehive .650 lift single springs
Chromoly pushrods
MLS gaskets
ARP head bolts
LS7 lifter set
YellaTerra rockers
Would come with valve covers to oil pan.
Professionally built, roughly 9k miles on it w/o a single problem
Synthetic oil, hear it run before I pull it.
Asking $3,000
machine work was performed at Kelly Automotive out of St Paul .026" upper and .028" second ring gaps, piston to wall clearance is .0032-.0034", crankshaft end play is .003". I would have to check on bearing clearances but I believe they were .0015" for rods and mains.
This is a smoking deal on this engine, it is capable of some big time HP and I had nearly 4k into the shortblock alone.
317 heads that had a valve job and resurfaced when it was put together.
9.27:1 compression with a 71cc head.
Old School Heavy
