why wont hp tuners read ECM?
i bought hp tuners from someone on here a while ago and i just tried hooking it up to my ecm in my turbo s10 and when you go to scan the ecm it says "no voltage detected". i checked the voltage and its getting volts and the ground is good too. i tried this on two different computers and it still wont read. can the interface be the problem? when i plug the interface into the computer it reads the serial # and the computer detects the device so im not sure what the problem could be.
Every time I had this error was because pin 16 had no power.
Hook your HPTuners interface to the OBD2 port only, don't hook the USB cable.
If the green led doesn't light, you need to check fuses and power to OBD2 pin 16
LS1TECH Sponsor
This error means either:
a. your drivers aren't installed
b. you have a faulty usb cable
c. you have a faulty interface
Start by installing the drivers and if that doesn't work try a new usb cable if that doesn't work contact support.
This issue has nothing to do with the obd2 port of the vehicle in 99.9% of cases.
ok hooked it up to my truck just a little bit ago. turned ignition on, plugged interfface in, opened hp tuners, and then tried to read the ecm; nothing... and when i plug the interface into the computer the interface turns on so i know the cable is good and when i plug the interface into just the truck it also turns on so the cables work. but i dont recall installing any drivers but when i plug in the interface to the computer it doesnt prompt me for any drivers like the directions tell me.
