bayer-z28
05-06-2012, 09:49 AM
Well, It's taken me a while to get this done, was supposed to be on the winter build list, but a couple other things got in the way. Not sure why I put it off for so long, but it really wasn't that hard. Expensive? yeah, kinda. But I wouldn't cheap out on fuel system stuff. I've done it before and I've actually lost sleep over the fear of my baby burning to the ground. BUY QUALITY FUEL PARTS!! I seriously can't stress that enough!
Anyway. I was getting ~56lbs idle and 45lbs WOT at higher RPM's. Tried changing the stock regulator to a Deplhi unit and that didn't help. Even changed the fuel filter. no bueno. So it was time to plumb a return. I even check the pump and all of the connections.
I swear I thought I had more pics of the parts. But anyway, I ended up with 8 Jeg's hats and two boxes of fittings, hose, clamps, zip-ties and other misc items. I planned the build in my head, then mapped it out on scratch paper, then ordered. Still ended up needing some last minute parts, but it happens.
http://desmond.imageshack.us/Himg7/scaled.php?server=7&filename=img1904aw.jpg&res=landing
Cut your hatch and access the pump to remove the stock regulator. Just remove the c-clip that retains it and be SURE to remove the screen and the small o-ring.
http://desmond.imageshack.us/Himg816/scaled.php?server=816&filename=img2077g.jpg&res=landing
Then you can go underneath and loosen the tank straps a little. This "can" gain some wiggle room, but didn't allow me much as the tank was pretty much sitting on the Upper PHB. You can wiggle the stock lines loose and pull them out from up top. Then you can go underneath, remove the stock steel return line from the T which is aft the fuel filter.
Now the fun begins! -Seriously, I love making these lines. :) Start routing your braided lines. Tape off the ends to eliminate getting crap in the lines. I attached one hose end and snaked the hose through, find the length you need, cut and attach the other hose end.
http://desmond.imageshack.us/Himg854/scaled.php?server=854&filename=img2087gm.jpg&res=landing
http://desmond.imageshack.us/Himg827/scaled.php?server=827&filename=img2086nr.jpg&res=landing
I just used a 3/8" -6 quick disconnect fitting for the filter, then route the line forward. Used some 1500* heat tape for where the line routes over and anywhere NEAR the exhaust. I know we're "technically" not supposed to zip-tie the hose to anything else, but.......... It wasn't going to work routing these along the SFC's. I may re-do it some time, but I'm not in a hurry.
http://desmond.imageshack.us/Himg825/scaled.php?server=825&filename=img2088n.jpg&res=landing
It's actually about 2" away from the steering shaft, so don't panic. lol
http://desmond.imageshack.us/Himg406/scaled.php?server=406&filename=img0023sr.jpg&res=landing
Once the two lines are ran to the pump bucket, you're pretty much done back there.
http://desmond.imageshack.us/Himg843/scaled.php?server=843&filename=img2078u.jpg&res=landing
Had the stock return line TIG'd into a plug. Was a really bizarre fitting and couldn't find a plug for it and had to get the car out of the garage this week. -It's blocking the lawn mower. :lol:
http://sphotos.xx.fbcdn.net/hphotos-ash4/s720x720/303414_3524539003771_1581011704_2594096_691858836_ n.jpg
Go up front and find a spot for the regulator and see what length you will need for the return. (-6 in my case) Attach the return. This is a bypass regulator, so I'm running it as such.
Strong fuel pressure! :D
http://desmond.imageshack.us/Himg850/scaled.php?server=850&filename=img2075r.jpg&res=landing
At this point, you can just measure and cut your front pressure lines. I did a -8 up front and DID manage to find a Jegs 3/8 -8 quick disconnect fitting in black. No tree of adapters. Found an Aeromotive fitting -8ORB to -8 fitting for the FAST rails. (since I asked on here and nobody could seem to find me a definitive part number.)
After it's all plumbed, just cycle the key many times and check for leaks. You can also watch your gauge to see if the pressure is falling. In my case I had a small leak on the front of my rails where I must have cracked the crossover loose and forgot to attach it. No big deal. Snug it up recheck, recheck and clean up the spots of fuel. Backed it out of the garage and shut it off (ran for 10 seconds).. Then got a bucket of soapy water and doused the engine compartment to wash out any of the fuel that had spilled. Rinsed it off, ran the car to warm-up and continue to check for leaks.
I drove mine and found a leak at the feed line 90* fitting to the regulator which was easily fixed. I don't like the angle of the feed line, so I'm gonna look into maybe a 45* fitting to see if that will take some stress off the line. Was a hard time finding a place for the regulator. Was going to hit the hood either way.
http://desmond.imageshack.us/Himg401/scaled.php?server=401&filename=img2093y.jpg&res=landing
Anyway... All i have to do now is correct the tune. The pressure sits solid at 60* now. Runs 10.5 a/f at WOT now.. :lol: yeah, it's working..
http://sphotos.xx.fbcdn.net/hphotos-ash3/525674_3524625045922_1581011704_2594144_1557462389 _n.jpg
