stall and gear combinations
Moderator
Going back to 3.23s would knock your 80MPH cruise down
from about 2870 to 2500. I find I get a fair bit of clutch
(TCC) slip if I give it a little pedal and the higher gears
would push this out a little (less pedal for same grunt).
I think 3.42s are what the automatic should have had.
But anyway, if the highway drone is livable as-is then
you should probably keep the bigger gears as the higher
RPM and lower gas mileage are about the only downside.
342 with a 4000+ stall is the best combination IMO
I have 3.73 gears with a 28in tall tire which equates to a 3.42 gear. I have a 3500 stall, but I am also making over 550 to the wheels.
id say 3500-3800 & 3.42's or 3.73's any combination is what would be your best midrange performer IMO if you want more street go with the 3500/3.42 combo if you want better drag racing #'s go with at least a 3800 & 3.73's
Generally speaking, 3.23-3.42/3500-3800.
I have 3.23s, an SS4000, a bit of tranny/converter programming done by yours truly, and I absolutely love it for street driving.
