General LSX Automobile Discussion - Does your dexcool "gum up" the dipstick?
Striker
05-11-2012, 04:03 PM
Here are some pics of what I'm talking about. Anyone else experience this?
http://i272.photobucket.com/albums/jj168/StrikerWS6/IMG-20120510-00111.jpg
http://i272.photobucket.com/albums/jj168/StrikerWS6/IMG-20120510-00113.jpg
http://i272.photobucket.com/albums/jj168/StrikerWS6/IMG-20120510-00114.jpg
Car spends a lot more time sitting than being driven.
Thoughts?
ULTIMATEORANGESS
05-11-2012, 04:15 PM
yes, its normal.
i dont have a problem with dexcool. many dont like it.
versz
05-11-2012, 05:35 PM
Breaks my heart everytime I check it...and that gum stuff doesn't come off. But its a small price to pay for dexcool
bww3588
05-11-2012, 09:48 PM
Normal in the over flow tank. Condensation collects in there, and when non distilled water mixes with dexcool, it will do that.
RevGTO
05-11-2012, 09:54 PM
Like everyone says, "normal" - not a problem. But at 13 years and 24k, if you've never had your cooling system flushed, you need to. Replace with G-05 or Prestone All Makes and forget about Dexcool sludge worries.
Striker
05-11-2012, 10:51 PM
I replaced it yesterday but I did put dexcool back in again.
Is there any benefits what so ever to running dexcool in gm's vs non dexcool?
RPM WS6
05-11-2012, 11:32 PM
My '02 looked like that when the coolant was 5 years old with ~70k miles. It cleaned right off the dipstick with some brake parts cleaner. I have not had that problem ever since, but I keep the coolant changed more often than the previous owner did.
99'CajunFirehawk157
05-11-2012, 11:34 PM
Flush that overflow tank every year or so, rad every 3yrs or so. YMMV.
I run it too fwiw.
chemicalstylez
05-12-2012, 09:14 PM
F dexcool. I used it once, and it clogged up everything. I'll never use it again.
bww3588
05-12-2012, 09:40 PM
Dexcool didn't ruin your system, something else did. Plain water, green coolant...that's what ruins dexcool is contaminants.
senicalj4579
05-12-2012, 09:50 PM
Iv owned 3 ls1s and never a problem with dexcool. I would do a flush though.
lees02WS6
05-12-2012, 10:00 PM
I've done two dexcool flushes myself, the only two it's gotten in the ten years I've owned it since it was new. Both were done with distilled water, I have not had any issues.
BAMALS1
05-13-2012, 12:06 AM
No issues here...mine has always been clean because I flush it regularly.
RPM WS6
05-13-2012, 03:02 AM
I run it too fwiw.
Coolant circulates between the overflow and the radiator with every heat up and cool down cycle, so if you change it regularly there shouldn't really be a need to do anything special with the overflow bottle, since fresh coolant is always mixing in. Only time I ever do anything special with the overflow tank specifically is if I'm starting with a car that's been neglected.
After 14 years, my '98 has a 100% original cooling system with zero issues of any kind. It's never seen anything but dexcool, changed regularly.
chaman
05-13-2012, 03:50 AM
Mine looks exactly like that.
NC01TA
05-14-2012, 08:58 AM
Just more info on Dexcool. No issues here with it. My dipstick is clean. I've flushed the system once (about 3 years ago at the 20,000 miles mark) since new, and I'm approaching 30,000 miles now.
mjs1012
05-21-2012, 10:57 AM
Mine has that too. I think it's normal.
thatoneguybriz
05-23-2012, 12:51 AM
Normal. If it bugs you, remove the over flow tank and clean it with a mild solvent or something containing citric acid. Don't forget to flush with clean water thoroughly before refilling.
