LT1 cam swap lacks power?
Old 05-18-2012, 06:29 AM
colt_impala's Avatar
Default LT1 cam swap lacks power?
I finally finished my camaro last night, and it is lacking power.
Mods include: heads shaved 30k, ported and polished, CC503 cam, Long tube pacesetters, and a few small things like msd coil, etc. At the moment I'm running open headers because I havent gotten the ORY yet.
Any ideas on why its lacking power? I know it needs to be tuned, but would that really make such a difference?
Old 05-18-2012, 07:38 AM
Luke1996ta's Avatar
Did u get codes? Fuel pressure ?
Old 05-18-2012, 08:03 AM
ahritchie's Avatar
You really got to ask Get a tune already....cam swaps REQUIRE a tune or it will run like ***.
Old 05-18-2012, 08:08 AM
93M6Formula's Avatar
What..
Old 05-18-2012, 08:40 AM
lt11994's Avatar
Do you have an Lt4 knock module? If not you could be getting false knock readings from the open headers and roller rockers which on turn retards timing....also you need a freaking tune
Old 05-18-2012, 09:51 AM
ZFreie's Avatar
I'm guessing you upgraded to bigger injectors?
cam swap means YOU MUST GET A TUNE, Christ even an mail order tune will make the car drive-able.
I'd be worried about ruining your engine from the excess fuel being dumped into the cylinders at the least.
Old 05-18-2012, 10:17 AM
ahritchie's Avatar
Originally Posted by 93M6Formula
What..
I assume he means heads are milled .030.... Shaving is for vaginas
Bumping up the compression.....yet even more reasons to GET A FREAKING TUNE ALREADY
Old 05-18-2012, 10:24 AM
sleepy_z's Avatar
Let us know how it feels after the tune.
Old 05-18-2012, 10:27 AM
RamAir95TA's Avatar
Tune - duh.
Old 05-18-2012, 12:00 PM
1_MEANZ28's Avatar
tune.and mabe the open header is affecting the back pressure
Old 05-18-2012, 12:01 PM
DisasterFormula's Avatar
Clearly it's your Opti!....Seriously guy, get a tune.
Old 05-18-2012, 01:06 PM
lt1-xjs's Avatar
He can't use the LT4 knock module.
Old 05-18-2012, 02:20 PM
Keep in mind this is the first computer controlled car I've done a cam swap on, hence why I didnt know the tune would have such an impact. Also, the injectors are stock.
Old 05-18-2012, 02:29 PM
ahritchie's Avatar
Ignorance is no excuse....it's always best to do your research BEFORE jumping into modifying your car no matter if carbed or computer controlled or you run into easily preventable problems like you are experiencing now....nothing worse than dumping a bunch of money on your car and having it run worse than when you started This happens a lot on here for some reason lol. Next time, research first, ask questions second; mod last
Old 05-18-2012, 07:21 PM
gregrob's Avatar
No tune needed. Most cam swaps require nitrous to really run well. Start at a 200 shot and go up from there. It will run hard, until it doesn't.
Old 05-18-2012, 09:00 PM
wrd1972's Avatar
Old 05-18-2012, 10:20 PM
rich5368's Avatar
Literally spit my beer I had just been drinking at my screen when I read this.. Bwahahahaha..
Old 05-18-2012, 11:57 PM
gregrob's Avatar
Old 05-19-2012, 10:59 AM
Speedy's Avatar
K. Without making fun, you need a tune (your car has the chip that needs to be burned). You need the Bosch 28lb injectors (Ford older redtop large size type). DO NOT run the new injectors without a tune, you will ruin your engine.
Old 05-19-2012, 01:17 PM
nitrous2fast's Avatar
"Lacking Power" is very vague... How much power do you suppose it is lacking??
Quick Reply: LT1 cam swap lacks power?
