Clear Corners?
Clear Corners?
Where are you all getting them? I checked 6LE thinking he would have them but No dice. I bought a pair off ebay and less than 6 months later they are all fogged up and ****. It looks like **** so I need a good quality pair!
Get a set from ebay seller neondials. They have the better quality ones.
Basically 90% of the corners on there are the crappy leaky melty ones. The ones that neondials carries are better quality plastic, have a heat shield in them, and actually seal the lenses also.
Internet Mechanic
Yea, quality is one thing. If your getting moisture, you need to get a hair dryer / heat guy, and dry the **** out of the lense and inside bucket that holds the bulb, any residual moisture will come back otherwise.
Had that with heads lights in my buick. Spent 2 hours with a hair dry making it ultra dry.
