Clear Corners?
Old May 20, 2012 | 06:42 PM
Grn4fbody's Avatar
Default Clear Corners?
Where are you all getting them? I checked 6LE thinking he would have them but No dice. I bought a pair off ebay and less than 6 months later they are all fogged up and ****. It looks like **** so I need a good quality pair!
Old May 20, 2012 | 09:33 PM
SparkyJJO's Avatar
Get a set from ebay seller neondials. They have the better quality ones.
Basically 90% of the corners on there are the crappy leaky melty ones. The ones that neondials carries are better quality plastic, have a heat shield in them, and actually seal the lenses also.
Old May 21, 2012 | 08:26 AM
PGUFF's Avatar
I think a lot of the ebay ones are luck of the draw. Quality control is poor. If the seller mentioned has good reviews, best to try them.
Old May 21, 2012 | 09:39 AM
Undertow74's Avatar
I have a full set front and rears that im looking to get rid of. Took them off my car a while ago because i put smoked on. They are basically brand new, car sits in the garage. Let me know if interested......
Old May 21, 2012 | 11:59 AM
CamaroSS27's Avatar
this.
Old May 21, 2012 | 12:39 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Yea, quality is one thing. If your getting moisture, you need to get a hair dryer / heat guy, and dry the **** out of the lense and inside bucket that holds the bulb, any residual moisture will come back otherwise.
Had that with heads lights in my buick. Spent 2 hours with a hair dry making it ultra dry.
Old May 21, 2012 | 12:42 PM
MonmouthCtyLS7's Avatar
eBay, amazon , anywhere
Old May 21, 2012 | 05:17 PM
The Guz's Avatar
You want these. They are made by depot. Search depo on ebay and you will see them.
Old Jun 5, 2012 | 01:01 PM
LS1121's Avatar
OK so I got the lights from neondials. Do I need to seal these or anything else before I install them?
Old Jun 5, 2012 | 02:25 PM
SparkyJJO's Avatar
It wouldn't hurt to run some silicone around the whole edge if you want to be sure I guess, but I never did.
Old Jun 5, 2012 | 08:39 PM
joshua cobos's Avatar
ebay here
Old Jun 6, 2012 | 09:36 PM
Andrew1989's Avatar
I got mine off ebay, don't recall seller but I put nice bead of clear silicone around the seal and they are 100% moisture free 3 years later.
