Post Pics of your cutout location!
First off, if this needs to be moved to the Tools and Fabrication secion, go ahead...
I need to see the location of cutout pipes on the i pipe, like how close to the axle or front it is... I need to have my cutout in before i install my headers and ORY, so I was thinking on the catback pipe, just north of the axle somewhere. If someone has anything to share or add, please post! But what i really want is PICS!
Thanks guys.
Thanks guys.
the best location is on the ORY itself right before the catback where it bends over the axle, that is where mine is, why dont you just put it behins the stock ory keep in mind you may want to wait cause your ory size will change from stock more than likely and you will want atleast a 3 inch cutout I would assume
Xx...
Check out Post #4 of the following Thread.
https://ls1tech.com/forums/generatio...outs-pics.html
Post #3.
https://ls1tech.com/forums/generatio...e-cutouts.html
And the 1st Post in this thread has some small, but very informative pics...
https://ls1tech.com/forums/generatio...ed-i-pipe.html
Post #3.
Mine resides in the real estate that the rear passenger bottom seat cushion used to take up. I cut the floor. Bout the only way to tuck a 4 inch cutout
