Squeak at low rpms not the belt
My car recently started squeaking at low rpms not so much at idle but when driving down the road an let off the gas when it drops to about 1000 how ever it has done it at idle once before its a really high pith intermittent squeak, my pressure at idle is 20 which is well above gm's 6 spec any Leo is greatly appreciated this is my daily driver thanks guys!
Village Troll
I know you said it's not the belt, but do not know how you came to that conclusion? Did you take the belt off and run the engine? I had a funny squeak as well and thought it was a problem rocker. Did the same thing you're describing. Found out it was the #1 primary on my LT's that was making contact with the brake line heat shielding.
I have an intermittant annoying squeak and its the AC compressor pulley or maybe its bearing. I have to spray it from time to time with WD40 and then its quiet for months or until it gets wet.
Idler pulley is also a usual suspect. You should pull the belt to further diagnose.
