Can I switch subframe connectors?
Old 03-30-2004, 12:47 PM
DVST8OR's Avatar
Question Can I switch subframe connectors?
I have subframe connectors already welded to my car. Can I get these removed (don't know how, looking for an answer to that as well) and have a new set welded on? Or would that cause too much structural weakness?
Thanks,
Brian
Old 03-30-2004, 04:42 PM
droopy726's Avatar
i heard of it being done before w/ a plasma cutter, dont know too much bout the structural integrity, how come you want to change?
Old 03-31-2004, 01:25 PM
DVST8OR's Avatar
I have MAC subframes on right now and I am not too sure about there quality / abilities. I was looking into replacing them with the G2 subframes.
Old 03-31-2004, 03:34 PM
droopy726's Avatar
I got the g2's well worth it, try posting on the arizona fbody board, im sure theres guys w/ connections to shops that can help you.
Old 03-31-2004, 05:01 PM
DVST8OR's Avatar
Well I know of a few shops that I can go to to get it done. I just wanted to know about how to go about removing them, and whether or not it is a good idea.
Old 04-01-2004, 05:06 PM
DVST8OR's Avatar
anyone want to help me out here?
Old 04-01-2004, 07:38 PM
chief455's Avatar
best way I can think of after doig many frame off restos on older cars.
Get the car in the air then get the wheels so the body weight is on them - simulated sitting on the ground. Then plasma cut or die grind the old wels. Clean the frames up and install new connectors per instructions. The risk of integrity loss would be if you cut the connectors while the front or rear frame could flex. While sitting on the tires shouldn't be an issue.
Old 04-02-2004, 12:48 AM
DONAIMIAN's Avatar
I agree with the grinding them off at the welds.
Old 04-02-2004, 12:48 PM
DVST8OR's Avatar
Cool, thanks.
Old 04-02-2004, 06:30 PM
tuffluck's Avatar
i doubt switching subframe connectors is going to be worth the time/money/effort unless your previous pair was a set of clothes hangers.
Old 04-07-2004, 01:33 PM
5150Z28's Avatar
It would be worth the effort in my case - When I had the LT's on with a custom 3" y-pipe it would hit the subframe connector (KBDD) on the drivers side under hard exceleration. It was just too damn close the the subframe. If I had BMR or GW subframes on I wouldn't have had this issue.
