Camshaft Help ( PVT ) Clearance
Been speaking with several camshaft companies about options. However they are all over the board on suggestions. So I thought that I would ask here and see what ya'll would recomend with my set-up. I dont want to have to worry about the old dreaded ( PVT ) issue.
Car is a 1999 Z-28 Stock motor.
1 3/4” ORY With hooker cat back.
Trans Auto with a PTC 3600 Lock-up convertor
rearend gear 3:42 I am almost 100% sure
Intake Fast 90 With a Nick Williams 90 TB
Heads are Patriot Performance Stage 2 P/N 2033
These heads provide up to a 65 cfm improvement over stock OEM versions. The 59cc chambers, will increase the compression on a stock LS1 from 10-1 to 11-1 Original Patriot Gold Dual .650” Lift springs, titanium retainers, Super 7 machined locks, custom honed bronze guides, machined spring bases, and viton rubber seals.
Thanks for all of you help.
No not at all. More compression=more power. Bigger cams aren't always better anyway. If you want a bigger cam you may have to flycut pistons. You want a minimum of .060 ptv clearance.
Clearance
Everyone, thanks fro all of your input. Iam kinda new to the LS1 world.
Streetknight, I actually spoke with Geoff this afternoon about a cam. He actually asked me to check a couple of thinhs on my heads tonight. I did and will be back in touch with him tomorrow.
However, things may of changed a little as of this evening. I may purchase a 6.0 short block and just build it and keep the original 5.7 stock. Not for sure yet though. Gonna sleep on it tonight and decide tomorrow.
