Stock replacement LS6 pistons
Old 06-29-2012, 09:31 AM
Bowtie70SS's Avatar
Default Stock replacement LS6 pistons
I just got a "great" deal on a LS6 long block and because of how the deal went down and the dead flies,dog hair, and dirt from this hicks mobile home I tore into it. I found used head gaskets and bolts, the piston tops look good(were cleaned) but i rotated th engine and 3 cylinders have had rust in them that was cleaned out. I havent pulled the pan but i expect the worst. I am thinking it will need bored .010 to clean everything up. This is going into a stock Z06 that lost its shortblock to a valvespring. What pistons are out there that are closest to stock? I dont want something that is 120 each either. Thanks.
Old 06-29-2012, 10:21 AM
parks450's Avatar
SpeedPro, for stock. Also unless those are ARP or other reusable bolts throw them in the garbage. Stock bolts are TTY bolts. If the gaskets have been ran for any amount of time throw them to, especially If they came off a different motor.
Old 06-29-2012, 10:37 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Mahle has some very affordable 4032 forged pistons that utilize your stock rods. They have a few bore sizes to chose from as well, and start at -4cc volume on their flat-tops.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 06-29-2012, 10:54 AM
Bowtie70SS's Avatar
Thank you. I am trying to put this back right. Were the stock pistons forged or hyperutectic?
Old 06-29-2012, 11:01 AM
Bowtie70SS's Avatar
Old 06-29-2012, 02:20 PM
Fry_'s Avatar
Are the Mahle's stock weight or would they require you to re-balance your crank?
Old 06-29-2012, 09:47 PM
Bowtie70SS's Avatar
I am curious about that too but I think I would rebalance regardless of which pistons I used.
Old 06-29-2012, 10:02 PM
parks450's Avatar
Stock are hyperutectic, you wouldn't need to rebalance but it's a good idea
Old 06-29-2012, 11:28 PM
BackNBlue's Avatar
I would absolutely rebalance. 2 different brands of hyperutectic pistons can have different weights and even if they were stock pistons it couldn't hurt.
Old 06-30-2012, 12:27 AM
TransAmcoupe98's Avatar
I def spend the cash for better bottom end man. What a great time to build it. At least get some better rod bolts (Arp or Katech).
Old 06-30-2012, 12:45 AM
intenseblue's Avatar
I would check out Diamond's
Quick Reply: Stock replacement LS6 pistons
