Fueling & Injection - 5.3l and 6.0l injector differences
Dillon93dillon
07-09-2012, 10:05 PM
So i have been having problems with my 2000 5.3l having a slight missfire, it doesnt register enough to throw any DTC's.
I swapped a known good set of coils, and it did no difference.
i also took a set of 2004 i believe, drive by wire 6.0l injectors, and swapped them in there. but it seemed to get worse...
i noticed the 5.3l had 4 nozzle holes, 6.0l had 2 nozzle holes...
are these not interchangable? or do they have to be from another 5.3l to test them?
any help is greatly appreciated. tired of seeing my LS sit
FICINJECTORS
07-09-2012, 10:51 PM
:bomb:So i have been having problems with my 2000 5.3l having a slight missfire, it doesnt register enough to throw any DTC's.
any help is greatly appreciated. tired of seeing my LS sit2001 to 2007 5.3 and 6.0 share the same injector unless it's a flex fuel. Unfortunately the 2000 is different
Dillon93dillon
07-10-2012, 12:33 AM
:bomb:2001 to 2007 5.3 and 6.0 share the same injector unless it's a flex fuel. Unfortunately the 2000 is different
wow so im S.O.L lol.
so the set of 04 injectors even if i did a whole set wont work?
i have a issue, with a slight missfire, but no DTC appears. i already tried coil packs.. last is injectors.. so im trying to narrow it down to which bank.. etc
FICINJECTORS
07-10-2012, 07:26 AM
give me the pn of your 2000 injector
Dillon93dillon
07-10-2012, 09:25 AM
25320288 i believe it said.
Dillon93dillon
07-10-2012, 03:56 PM
Can I put all 6.0l injectors in and be okay? Or do I need tuning to run them
FICINJECTORS
07-10-2012, 06:15 PM
The 2001 up is pn 25317628 which are 24.7 your 2000 has 21.7lbs so it would have to be tuned.
Dillon93dillon
07-17-2012, 09:31 AM
i hope that all it is is injectors..and i can just get some remans or something along those lines.
the missfire is a little less now that the rails were flushed some. but its way down on power
Dillon93dillon
07-18-2012, 12:26 AM
well i put another set of injectors in it today. a used set from a wrecking yard ( ya i know..)
but the problem is the exact same. each injector has power going to it ( tested with a noid light) but is it at the right time? idk...
this is strange how just one day it started to do this..
possibly a cam, crank, or knock sensor>
i really need help with this. anything is appreciated..
Thank
