Next Mods? Suggestions Welcomed.
Car- 1997 z28 A4 (75,096 miles)
Purpose - Weekend driver, no daily use, some track (down the road)
Current modifications -
1) Pacesetter coated long tube headers with AIR, EGR
2) 3 inch off road y-pipe no cats
3) Lingenfelter cold air intake
4) Underdrive pulley
5) UMI black powdercoated 2 point weld in SFC
6) UMI black powdercoated 2 point strut tower brace
7) MSD 8.5 super conductor wires
8) NGK Iridium plugs
9) GM High Performance Optispark
10) Rebuilt alternator
11) Rebuilt starter
12) Deep Cycle battery from autozone
13) Nitto NT05r drag tires (275/40/17)
14) Tune by Dynosport in Lincoln, Nebraska
**Some thoughts of whats next - UMI lca, UMI phb, UMI lca relocation brackets, strano springs, trickflow ceramic coated intake elbow, electric WP, 52mm TB, 1.6 RR & springs, 3:73 gears, eventually a stall down the road, aerotech 50 gauges in one on the pillar (might be for good use down the road??)**
I would like some input as to what I should do next?
Thanks,
Devin
11) Rebuilt starter
Thanks,
Devin
I'm a college student currently (money a little tight, but all the things u said I would love to do). How about I make a list here and see if you agree.
1)UMI lca
2) UMI phb
3) UMI lca relocation brackets
4) strano springs
5) trickflow ceramic coated intake elbow (resenator delete)
6) electric WP
7) 52mm TB
8) 1.6 RR & springs
9) 3:73 gears
10) eventually a stall down the road (which size tho?)
1)UMI lca
2) UMI phb
4) strano springs
6) electric WP
7) 52mm TB
8) 1.6 RR & springs
9) 3:73 gears
Upgrade your valvetrain when you swap in the cam. Rocker arms AND valve springs. If you know that you're going to do a cam swap, don't waste your money on a 52mm throttle body, just get a nice 58... AS&M, Holley, TPiS.
